Results 1 to 7 of 7
    Sep 2009
    Last night nag-blink na yung "H" warning ko pero hindi naman dumating sa point na hindi na nagbblink at naka-ilaw na lang. Pagdating ko sa bahay chineck ko kung ano possible problem. Check coolant reservoir (normal), Radiator Coolant level (normal). Upon further checking, napansin ko na may mga oil stains with dirt sa paligid ng engine, sinipat ko and dun ko nakita na may leak between the lines, yung nagdudugtong sa lower and upper part ng engine. Please advise if ang problem nito is sa gasket lang and if need ko na din mag change nung gasket.
    Also checked the oil level and mejo mababa na nga cia so I've decided to temporarily added some to replaced the lost oils.
    Honda City I-Dsi (2004) CVT
    TIA
    Jun 2004
    Is it from the valve cover or somewhere else? Normally pinapalitan valve cover gaskets (plus spark plug oil seals if applicable). Madali lang naman yun at mura lang, kahit DIY kaya.
    Sep 2009
    Pag binuksan ko ba yung valve cover nun walang piyesa na mahirap ibalik pagkatapos. Baka kasi may mga springs dun tapos pagbukas ko maglundagan tapos di ko na maibalik. TIA.
    Mar 2012
    naku. ako may oil leak din, pina check ko kanina parang may tagas oil seal nang tranny. kailangan ibaba at palitan nang oil seal. di naman daw aabot sa 7k. ok na kaya yun?
    Jun 2004
    Quote Originally Posted by marktams86 View Post
    Medyo mahal kasi dyan yung labor, nung nagpagawa ako sinabay ko na rear main seal, torque converter gasket?(a/t) at palit transmission fluid, yung labor nung sakin 2,500 yata, 2 days lahat lahat inabot.
    Jun 2004
    Quote Originally Posted by wezz_zzew View Post
    Sa pagkakaalam ko wala naman piyesa na iba na matatangal pag tinangal yung valve cover. Pero kung pagawa mo sa mechanic nde naman mahal labor, baka nasa 150-300 lang.
    Mar 2012
    Kakatapos ko lang magpa ayos nang oil seal . Binaba ang transmission halos umabot isang araw. Mga 4500 lahat.
    Sent from my GT-B5330 using Tapatalk now Free
Oil leak
