Results 1 to 7 of 7
- Apr 2011
- 7
April 8th, 2011 01:07 PM #1mga master tsikoters..
i just bought a used honda civic vti-s 2002.. and i wonder what would be the best oil for the engine.. i am really new for honda cars.. ano po ba maganda or best oil na ginagamit nyo for this car.. and especially po the transmission fluid..
replies are highly appreciated thanks...
- Apr 2011
- 27
April 9th, 2011 03:30 AM #2
Sa engine oil ay 15W-40, puwede na at pasok pa sa budget. Kung may budget ka ay Mobil 1 na 0W-40.
Sa tranny fluid ay walang iba kundi Honda ATF-Z1 lang. Pero mas maganda pag nagpalit ka ATF (automatic transmission fluid) ay pa flush mo ng Honda ATF-Z1 kasi di mo alam kung yung pinagabilhan mo ay original Honda ATF-Z1 ang ginamit dati. Mga 7 liters magagamit mo pag kasama flushing.
- Dec 2006
- 234
April 10th, 2011 09:45 AM #3you can't go wrong with Honda original lubricants, most specially with the ATF and PSF, they will be indicated in your car manual.
Personally, on my Accord, I use original Honda ATF-Z1 and PSF. For the engine I use Royal Purple 10W-40 from Speedyfix.
- Apr 2011
- 7
April 12th, 2011 07:14 PM #4thanks po sa mga replies.
i think ill go for a fully synthetic honda vteclev.. medyo masakit nga lang sa bulsa.. but i just wanna make sure para na din sa engine..
and i bough 3 liters of honda atf-z1 for my tranny.. since dextron 3 daw po ang ginamit dito.. medyo di din kasi ako sure about this dextron kya ngdecide ako mag change fluid.. ok lang ba yun?? me laman na dextron 3 tranny ko?? then papalitan ko sya ng honda-atf? di kaya ma damage tranny ko?? ?
i wonder ilang liters po ba ang magagamit ko para mg change ng automatic trans fluid???..
ang how often po tayo mg papalit nito?? ilang milyahe po ba bago magpa change fluid uli??
and about the psf?? is it ok to use some other brand ng power steering fluid pangdagdag lang ?
April 12th, 2011 08:08 PM #5
bro just check the manual (if available) and you cant go wrong. you may also ask any HONDA service advisor or honda ownerhere at tsikot with the same modelas you have for the oil / atf grade.
you can source out in the market the brand you want as long as the grade is within the specs...
- Apr 2011
- 27
April 13th, 2011 04:37 AM #6
Gaya ng nasabi ko sa previous post ko, kung other than ATF-Z1 ang atf sa car mo, dapat flush mo muna ng ATF-Z1. It means, drain the old ATF, including the torque converter. Refill with ATF-Z1, about 4.5 liters. Run the engine, shifting to all gear position, PRND2L. Idle engine until normal temp. Drain the fluid again (not including Torque Converter). Refill with ATF-Z1 to correct level (approx. 3.2 liters)
A reliable mechanic knows how to flush, then refill correctly.
Sa model ng car mo, ATF should be replaced every 40,000 kms.
Do not mix Honda PSF with any other brands of PSF, or ATF. Seals will fail and cause leak. Mahal pa overhaul ng PS pump at PS gearbox.
- Apr 2011
- 7
April 13th, 2011 02:51 PM #7patay.. me leak na nga po yung ps pump ko siguro.. . me tagas ng psf eh.. sabi sakin mechanic papalitan sya.. . dinadagdagan ko ng psf pro ibang brand ..nakita naman na ang ps gearbox is ok naman (bandang gitna) sa may manibela sa baba nya yung mga tubo dun me tagas at kelangan palitan... nung nabili ko kasi ganun na sya..
about sa atf.. ng change fluid na kami.. kaso 2.9 liters lang kinarga.. and diko lam if na flush lahat ng dati nitong atf. which is sa pagkakaalam ko eh dextron .. maybe ill go for another change atf uli..
and sa PSF. ill flush them too.. papalitan ko nalang ng honda PSF..
ang problema lang budget hahaha.. bigat..
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
