Results 1 to 10 of 34
- Nov 2008
- 16
February 8th, 2009 11:50 PM #1Mga sir, patulong naman po.
Nakabili ako ng second hand na 03 honda city idsi a/t
57k na yung mileage nya.
so far, okay naman.
pero patulong naman po dito:
1. may crack yung dashboard, san ko pede pagawa?
2. kapag nag leleft ako, ung steering wheel nya parang naglolock.
3. minsan may kumakalampag sa harap, sa steering wheel pag malubak,
san ko pede paayos ung mga kalampag?
4. ung makina pag matagal ng tumatakbo, parang umiingay na, parang
hinihingal.
5. para san po ung tune up? change oil?
6. san po mga shops na pede ko paayos? ung mura pero magaling?
7. paayos ng seat belt? kasi pag tumatakbo, may tumutunog sa gilid.
mga magkano kaya magagastos ko paayos ng lahat?
salamat po!
- Feb 2009
- 43
February 9th, 2009 05:33 AM #2
- Nov 2008
- 16
Tsikot Member Rank 3
- Mar 2004
- 2,053
February 9th, 2009 05:51 PM #4Saan sa dashboard yung crack? AFAIK, wala ka na ata magagawa dito save for ordering a replacement dash from Honda. Kung yung crack nandoon sa painted portion (HU and steering wheel area), baka pwede mong i-patch + repaint. But if the crack is on the unpainted section....
For the rest of the problems.. you can try SpeedyFix. Better yet, go to the CASA and have your car checked. Then get the list of the problems, and bring your car to SpeedyFix and have them take care of it .
February 9th, 2009 06:17 PM #5
Some shops who do leather and car interior can repair the damaged dash board by filling in the crack and then painting the entire dashboard to mask the repair. There is one place I know near the city hall of Mandaluyong City.
BTW, thats only if the crack is on a hard part of the dash. If it's on a soft part, they can use some color matched leather to wrap the dashboard to hide the problem.Last edited by ghosthunter; February 9th, 2009 at 06:19 PM.
February 9th, 2009 07:58 PM #6
congratz din po.
ako new owner din kabibili ko lang last month 2nd hand honda city vtech 1.5 2004 model. 380k naman. only problem was i had to replace the tires kasi medyo pudpod na.
good luck sana maayos po ninyo yung mga problems.
- Nov 2008
- 16
February 9th, 2009 08:21 PM #7salamat mga sir,
magpost ako ng pic for the crack.
asa radio sya, sa gilid...
san po loc ng speedyfix?
February 10th, 2009 09:11 AM #8
this might help you more about speedyfix...
http://tsikot.yehey.com/forums/showthread.php?p=815922
- Mar 2004
- 2,053
February 10th, 2009 12:25 PM #10Hindi ata pwedeng ipa re-upholster ito. The dash of the cith'03 is mainly molded plastic with a leather like surface texture. Two tone yan -- Dark beige/Light beige if your car is black or metallic beige, dark gray/light gray otherwise. If your crack lies on the molded plastic part, then even if you can seal up the patch with a matching colored putty, it will still be highly visible unless you can match the molded texture.
The head unit (center) and instrument panel part of the dashboard is painted. It has no texture (smooth). This makes it easy to repair. If the crack is in that area, it's a simple matter of applying putty and repainting.
Saan part ba ng dashboard yung may crack? Baka pwede mo na lang lagyan ng dashboard ornament or air freshener yung part na yon para matago. Hassle din magpapalit ng dashboard. Kung palitan yan, you run the risk of introducing rattling/kalampag.
Traffic!
