Results 31 to 34 of 34
September 7th, 2009 08:00 AM #31
malas naman..parang ang hirap mag drive ng auto knowing na may crack yung transimission. better to get second opinion sa casa , pag confirm, kung ako sa iyo i will sell the car then look for a better second hand car. 100K for a transmission repairs?? estimate pa lang yan.. pero if you plan to keep the car pwede din kaso baka may madiskubre ka na naman hinde maganda at isumpa talaga yung nagbenta sa iyo.
September 7th, 2009 09:15 AM #32
Iyong sa steering wheel parang naglalock . check mo iyong power steering fluid mo baka kulang ang laman at marumi na kailangan palitan . Kung mapula kulay ayos pa iyan .Kung maitim na at brown papalitan mo na.
I pa check mo suspension mo sa ilalaim baka mayroon ng kailangan palitan .Pagnapalitan na iyong mga sira i pa wheel alighnment at camber kung kailangan.
Sabi mo second hand mo nakuha sasakyan mas maganda TUNE -UP.
1. Change oil .Replace with oem oil filter
2. Power steering fluid.
3.ATF fluid sa transmission.
4.change brake fluid
5. Drain radiator .replace with new distlled water 50/50 mix with coolant.
6.Check all break pads ,very important
7 . replaced spark plug.
8. Replace or clean air filter.
9.Check spark plug wire set
10. check engine timing.
11. Check all hose. Radiator hose for leak.,powersteering hose , brake hose
12. Disributor cap, rotor
13.Check all leak . Valve cover gasket., drain oil plug., Crank case gasket and others.
Note# CHECK MO MUNA LAHAT ITO HINDI NATIN ALAM DOON SA DATING MAY ARI KUNG KAILAN PINALITAN. AT KUNG PAANO NIYA INALAGAAN ANG SASAKYAN.
- Mar 2009
- 48
September 8th, 2009 12:52 PM #338 spark plugs! correct. dahil I-DSI. pero yung mga iba. 4 lang. kung sa pang ilalim pa check mo zafra or other shops, have a second and third opinion, baka naman iba yung sira. to tell you honestly bro, hindi kaya yung nabili mong city ay may tama na. yung nabangga na dati kaya ibinenta. dahil yung mga sira niya ay ay puro related sa isat-isa. like yung pang ilalim niya, steering and the cracK DASHBOARD., did u ask the seller, kung bakit may crack yung dash board? kung paano nagka ganun? i don't want to sound bad to you, but it seems probleamtic yung city. tama yung sabi ng isa sa thread, have it brought to cas, then get the service report, tapos dalin mo sa reputable shops na magaleng, check all the threads here, maraming recommended na talyer. para sa parts na mura and orig, punta ka sa pasay -taft rotonda, ilalim ng MRT, may auto shops dun na mura and orig na parts, Car Power and Part star. goddluck bro...
- 199
September 8th, 2009 08:49 PM #34tama sila kapatid, pa check mo muna sa casa, then tsaka mo dalhin sa reputable mekaniks. =) at least makaka tipid ka dun
Production of the next gen Kicks confirmed .......
2025 Nissan Kicks
