Hello, guys! This is my first ever post here, and I'm gonna be talking about my problems with my Civic ESi A/T. Really hoping to get enlightenment as to what's causing the issues below and if they are interrelated. Need your expert opinions and ideas to help get the car back in normal, healthy state. I'm thinking D.I.Y. for whichever you believe could be manageable. Please don't mind that I'm a girl. I am hell-bent on learning automotive stuff. Plus, I have my cousin and brother to take care of what I can't handle.
Here's the rundown...
- Car's temp's been going up slightly past the middle line every time it's running at 80 to 90 kph or beyond. It goes back down to normal temp once I ease up on the accelerator and slow down to within 60 to 70 kph.- ( Check your radiator coolant level first, then the radiator fan if it is running when the temperature level reaches before the middle line.)
- Engine stalls during sudden braking to full stop. A big embarrassment especially when driving in very busy roads! - ( Have your idling RPM checked. )
- The car's pinging (
http://www.autoindustriya.com/talkbo...nd-%27tope%27/) a few weeks back has lessened to a considerable extent after a friend's mechanic turned the distributor to full (todo!)advanced timing position. The car has become more responsive as well since then. There's still slight occasional pinging, but it's no longer as annoying as before. The full advanced timing, however, worries me as it's not normal. I would, of course, prefer more responsiveness and no pinging na naka-normal lang yung position ng distributor, and not advanced or retarded/delayed. - ( The cause of this problem is that the ignition timing is advanced beyond specs. Better use a timing light when checking and adjusting the ignition timing.)
- Front brakes squeal even with new brake pads. Left brake rotor needs refacing, said the mechanic who installed the new brake pads. Could that really be the cause of the squeal? ( No need to reface the rotors, that is sometimes normal for replacement brake pads. It will wear out as you normally use the car.)
- Noise coming from the left front side, somewhere involving the wheel perhaps, every time I speed up at 65 kph and over, and gets louder as I go faster. Sounds like "ugong." My cuz and I were thinking wheel bearing, although we're not at all sure.- ( The cause of the " ugong" is worn out wheel bearing. Have it replace with a branded bearing such as SKF, NSK. But make sure the mechanic or shop has proper bearing fitting tool set.)
- We noticed the water from the radiator, with cap removed, rise up the opening when car is revved. And when engine is started with rad cap removed, the water spurts out the opening. There are also days when tiny bubbles that look like soap suds form on top. Other than that, water's clear and we didn't see any signs of oil mixture. - ( Have your radiator checked for any cloggings, rust formation. )
- Just had a 15 amp fuse (for the radiator fan) replaced a couple of weeks ago, but yesterday my cousin and I found out its plastic is melting. Then upon inspecting the other fuses, we saw another one (20 amp) that's also on its way to getting busted. A friend who knows only basic electrical stuff thought there could be a grounding problem somewhere and advised me to have the car checked. I intend to do just that, but I thought I'd get some ideas from in here so I wouldn't sound totally ignorant when talking this out with an auto electrician. - ( There might be a short circuit or grounding on the radiator fan circuit. Have this checked by a competent auto electrician equipped with proper tools and tester. )
Hear from you soon, guys! Thanks!
