Car's temp's been going up slightly past the middle line every time it's running at 80 to 90 kph or beyond. It goes back down to normal temp once I ease up on the accelerator and slow down to within 60 to 70 kph. ---Overheat has a lot of possible cause. But based on that observations, I guess you have a dirty radiator, and faulty fan. Also please check your thermostat valve. These valve is responsible for stabilizing your cooling temperature. If these valve is faulty, you will have higher temperature on higher revs.
- Engine stalls during sudden braking to full stop. A big embarrassment especially when driving in very busy roads!
---check your transmision fluid level,check you torque converter clutch soleniod, better still have your a/t checked sa a/t expert sa banawe.
The car's pinging a few weeks back has lessened to a considerable extent after a friend's mechanic turned the distributor to full (todo!)advanced timing position. The car has become more responsive as well since then. There's still slight occasional pinging, but it's no longer as annoying as before. The full advanced timing, however, worries me as it's not normal. I would, of course, prefer more responsiveness and no pinging na naka-normal lang yung position ng distributor, and not advanced or retarded/delayed
The engine pinging is caused by premature ignition. That means your timing is too advanced. This happens when you fill you gas tank with a wide range of octane rating on the fuel. That mean if you put in PETRON extra now which is at 89 Octane (on the board 92) your engine will run well, BUT if you put in blaze 95Octane, there will be pinging. I suggest set your timing to a specified fuel and be loyal to that fuel. That will solve your intermittent pinging.
Front brakes squeal even with new brake pads. Left brake rotor needs refacing, said the mechanic who installed the new brake pads. Could that really be the cause of the squeal?
Personally I dont like bendix for japanese cars. Bendix is good for Holden, or American cars. Since you have a honda, use Nissin brake pads which is compatible with the cast Iron material used by honda. These are available sa PASAY taft sa Car Power or sa other honda autosupply. I think that will solve the squealing, the bendix is a squealer.
Noise coming from the left front side, somewhere involving the wheel perhaps, every time I speed up at 65 kph and over, and gets louder as I go faster. Sounds like "ugong." My cuz and I were thinking wheel bearing, although we're not at all sure
I suggest ether you repack or replace your bearing. Also have your wheels aligned both toe and camber
We noticed the water from the radiator, with cap removed, rise up the opening when car is revved. And when engine is started with rad cap removed, the water spurts out the opening. There are also days when tiny bubbles that look like soap suds form on top. Other than that, water's clear and we didn't see any signs of oil mixture.
That could be a sign that your thermostat Valve is stuck. Also foaming in the radiator is a sign of internal leakage. That is heat pressure from the cylinder leaking through the cylinder head gasket. Have your head gasket checked. It may be also contribute to your overheating problem.
Fuse Blown. Check youre lines form the fuse box to the fan. Find the shorted line, or check if your relay is still ok. Otherwise, replace fuse and relay.
