Results 1 to 6 of 6
    Aug 2009
    good day masters!
    i just bought my first car its a 2nd hand 1998 civic lxi 1998 . since i dont have any background when it comes to automobile. what are the usual things that i need to check/replace. just got it today and im still learning how to drive it. some of my friends told me to have the oil changed, check the wheel alignment, etc... (these are all jargon to me)
    any reputable honda shops near sm fairview that i can go to for us to check the status of my ride?
    thanks in advance and more power!
    - oil change
    - transmission fluid change
    - radiator flushed
    - change filters
    - check engine belts
    - change timing belt (depends on the odo reading), water pump and tensioner
    - check and replace tires (kung needed)
    - tune-up, change spark plugs, clean throttle body
    - check battery condition
    - check alternator condition
    - check suspension condition (including shocks)
    - check radiator condition
    i dont know of any shops in fairview..
    Dec 2009
    i would suggest if malapit kau sa honda tandang sora, if mgpapachange oil po kau dun worth just only php875.00 it also includes 18points of inspection, mabigyan nila kau ng recomendation... puede nyo po hintayin.
    re-wheel alignment nman po kung may nararamdaman po kau n pulling to left or pulling right, then there u need to check and perform wheel alignment, pra macheck ang toe in, toe out, camber setting etc...
    look mr.abet bernardo svc manager po sya dun matutulungan po kau nyan...
    Apr 2004
    change the timing belt... kung sa buy and sell galing yan i'm almost 90% sure the odometer will be clocked, especially when it reads below 50,000 kms.
    the usual, change oils, kalampag... basta get anything fixed that doesnt seem "right" in the car. your comfort should be paramount, kaya kalimutan mo muna yung mga banawe accessories like fancy LED lights or super loud radio. aanhin mo mga arte na yun pag pirmi ka naman tumitirik sa daan, diba?
    prepare some money, because you must focus on getting the car to run reliable. honda fairview will do a good job in reconditioning your car, but dont expect it to be cheap.
    basic tune ups, oil changes, i go to petron fairview in front of the servitek. they have fairly decent techs there.
    sadly, i know of no honda specialist shop (apart from honda fairview) in fairview, and i'm from fairview na. kaya for engine works i just go to honda fairview and pay a premium.
    Dec 2009
    hehe... same car din... kakakuha ko lang din... (naalala ko tuloy yung term na brand new recon sa mga tindang celphones sa greenhills)...
    gusto ko rin sana paltan yung mga dapat paltan (oil, belts, etc.) any ideas kung magkano kaya yung mga 'consumables' na to? pasensya na first car din kaya ala ako kaalam alam.
    Jan 2010
    Quote Originally Posted by 1D4LV View Post
    - oil change
    - radiator flushed
    - change filters
    This is a list the OP should print! Way to go, 1D4LV!
need help on my 98 civic lxi
