Results 1 to 2 of 2
- Nov 2009
- 1
November 25th, 2009 06:26 AM #1Mga sir im new here, i just need an urgent advice about changing engine.
My car is 91 EF sedan with a D12B1 carb engine, last diagnosis niya nung dinala ko siya sa forced speed sabi ni jeff is katok na daw and di na kaya for overhaul, i want to change my engine with a D15B vtec and im planning to do it this december....
So mga sir i need some basics and advice kung magkano price range ng D15B vtec, san maganda kumuha, magkano pakabit and nu mga recommendations niyo kung saan maganda magpakabit.....
November 25th, 2009 07:59 AM #2
san na ba sila jeff ngayon? last time i went to his shop it was in kalayaan ave....
sabi nya katok na? hmm. madami na threads dito about d15, i suggest you search around muna. pero ang bentahan nyan nasa 25-35k. kay kanzai 40k kasama kabit pati paandar.
pang hataw ba yang ef mo? kung pang daily commute lang i suggest a less expensive engine... like a ph12 from an eg hatch. or a ph15 carb from the sedan. this way hindi mo na kelangan mag convert ng fuel pump (pati yata gas tank eh, not sure) kasi EFI karamihan ng d15. there are carb versions, but medyo malakas na sa gas. since cost is an issue to you, wag ka na mag carb.
ang maganda lang sa carb... walang ECU na pwede mabaha... hehehe.
high idle RPM at engine start
