Results 1 to 18 of 18
    Aug 2012
    Paano po ba malalaman kung talagang kailangan ng palitan yung shocks?
    Hindi kasi ako sure kung palitin na talaga yung shocks ko. Hindi na kasi sya nag cocompress kapag uneven yung roads tapos parang "iniiwan" nung gulong yung kalsada na parang bato sa tigas yung pakiramdam. Naka maxspeed lowering springs kasi ako dati kaya feeling ko yun yung reason kung bakit nagkaganito yung shocks ko ngayon. Dapat pala ata magpapalit din ng shocks kapag nag lowering springs.
    Apr 2015
    First of; you can actually test it manually by taking off your shocks out of the car. 'You'll be needing spring compressor to do this'. Then try to squeeze the shaft against the body; by doing that, you can able to assess if there is less or enough resistance in movement of the shaft along with the force you applied. If there is less resistance or 'no' resistance at all, your shock is 'shot'.. You've got to change it..
    Aug 2012
    Quote Originally Posted by skotsephrenic View Post
    Thanks for the quick reply sir. I see yun pala yung way para macheck kung talagang kailangan ng palitan yung shock. Hindi yung hula hula lang.
    Meron kayang ganun sa mga shell gas stations? Particularly sa mindanao avenue.
    Well, if he'll go all through that might as well replaced it than just have it check. [emoji17]
    Apr 2015
    Check the shocks for any leaks, kung napansin mo basa yung paligid, palitin na yan.
    Aug 2012
    Quote Originally Posted by paulomik View Post
    Wala naman akong nakitang tumutulong langis sa shocks. Tapos nung diniinan ko yung right side sa harap with my weight bumalik lang sya pero di na ulit nag bounce. Pero nag iba kasi talaga yung ride nya e. ipacheck ko nalang mamaya sa shell service para sure. Thanks sa reply nyo sir. ��
    Wala naman akong nakitang tumutulong langis sa shocks. Tapos nung diniinan ko yung right side sa harap with my weight bumalik lang sya pero di na ulit nag bounce. Pero nag iba kasi talaga yung ride nya e. ipacheck ko nalang mamaya sa shell service para sure. Thanks sa reply nyo sir. 😊
    Sep 2012
    Quote Originally Posted by Troy Inovero View Post
    If your shocks is gas type wala ka talaga makikita na oil leak.
    Aug 2012
    Quote Originally Posted by jodski View Post
    Sir sa pagkakaalam ko po fluid type ang shocks ng jazz GE. Not 100% sure though.
    Oct 2009
    hindi mo malalamang sira na yan hanggat hindi mo binabaklas ang shock dun sa spring...
    saka mo hawakan ung dulo saka mo biglang diinan or itulak pababa.kapag biglang mo naitulak ng pababa ng hindi ka nahirapan.at hindi na bumalik ng kusa..
    sira na yan 100%
    sira na yan 100%
    Apr 2015
    One way to check it without removing the shocks is called 'suspension performance test' it is a computerised testing wherein all you have to do is put the 2 front wheel of ur car into a square metal flatform (approx 12" x 12") and it would act as a real world simulator by applying a dumping motion in ur front wheels for several seconds.. The computer will sense if the tension in your suspension is bilaterally equal or there is an imbalance of more than 50%.. This technolgy is used to check cars suspension much more accurately rather than going into traditional mechanical diagnosis by removing all those suspension.. ., there should be someone somewhere around there in manila area doing that.. No quite sure though but it would lessen the hassle of prying all those seized bolts out..
    If there's no one else's there you got no choice brother..
    Aug 2012
    Sir saang shop po may ganun? Mas accurate siguro yun ska less hassle.
    Most likely walang ganyan sa pinas lol. Sa US/EU highend suspension tuning shops meron.
    Kahit sa Wheeler Dealers garage ni Ed China walang ganyan. They still check the shocks the old fashioned way by just bouncing the corners. Works naman eh.
    Apr 2015
    Wow you're basing it on a tv show.. Are you based in UK?? Anyways it used on every single car being tested yearly to assess road worthiness of all cars on the road not single out suspensions alone.. FYI the test is called NCT.. Google it for more info..
    Apr 2015
    I live in IRELAND..
    Apr 2015
    Dec 2013
    Best way to test it is by "actual feel" during driving. When shock absorbers go bad, the shaft gets stuck at the bottom and isn't strong enough to retract and push the car back up. Ibig sabihin, kapag nalubak ka, wala ng mag-aabsorb ng impact pababa so yung coil spring at suspension parts ang sasalo ng force. Definitely, mararamdaman mo to sa loob ng cabin.
    Jun 2011
    IMO replaced it every 80k kms.. Or earlier, Or any signs of wear sa tires.. Or pag hindi na stable sa high speeds ang car mo, even if their is no signs of wear on your shocks or tires...
Need help about shocks
