Results 21 to 30 of 30
- Feb 2008
- 82
April 15th, 2008 08:28 AM #21Thanks for the info. OMG mahilig pa naman ako tumapak sa brakes waaaah
April 15th, 2008 11:32 AM #22
+1 yung post ni mbeige.
naging discussion yan sa isang thread dito, di ko lang mahanap. also sa forum ng honda club.
- Apr 2008
- 42
May 9th, 2008 02:09 AM #23"Sunog" - meaning overheated brakes, causing brake malfunction - mawawalan ng kapit yung "clamps" sa disks.
May 9th, 2008 07:11 AM #24
May 23rd, 2008 02:25 AM #25
The first thing the SA and technicians told me about conventional ATs is that you never shift while the vehicle is moving. Always come to a dead stop when you want to shift from D to L1, or from D to N.
Even with a manual mode, I was told not to shift from any forward gear to N while moving.
May 23rd, 2008 06:32 AM #26
I know my car's manual even recommends "sporty driving habits" if desired by manually shifting gears with the A/T. Maybe he was just playing it safe by tell you that in order to prevent owners from over revving the engine. It can happen if you're not careful.
Of course, D to N can only be completely safely done at a stop, because if you suddenly had the need to shift back into D, doing so on the fly will definitely hurt your engine and transmission. Shifting from D to L1 should be fine - just read your owner's manual, practice shifting first so you know at what RPM the engine spins at what given speed so you can gauge if you're going to over rev the engine if you shift to a lower gear manually.
Drive safely.
May 23rd, 2008 09:28 AM #27
yup damaging sa AT pag shift ka to N from D on high speed, sa manual ok lang.. but the down side is, if there is a sudden emergency di ka agad makakaalis at baka makalimutan mong nasa N ka.. pag tapak mo sa gas, di bumilis as you need it..
delicado!
May 23rd, 2008 10:26 AM #28
sa m/t ok lang kaya lang walang engine brake.. so medyo delikado talaga.
Tsikot Member Rank 4
- Jun 2006
- 2,605
May 23rd, 2008 10:47 AM #30
Xiaomi E-Car
