Results 11 to 14 of 14
May 4th, 2008 11:19 PM #11
May 4th, 2008 11:27 PM #12
Based on an SGI-LPG kit in a 2nd gen CRV, the installer will need to drill two holes to pass the fuel lines through and bolt down the tank. Assuming its a donut tank installation, it would be through the floor under the picnic table. If the floor has pre-drilled holes, the LPG installer with use those.
LPG fillers are typically installed under the bumper for CRVs so no cutting to install this.
SGI-LPG kits need to drill a hole in every intake manifold running to attach the LPG injector feed hoses. When removed, the holes can be sealed using a screw cap.
In the end, only the engine intake manifold will be the obvious sign that the vehicle has previously fitted with auto-LPG. Even then it would take a very meticulous buyer with close familiarity for the CRV's engine to spot it.
- Feb 2008
- 33
May 6th, 2008 02:07 AM #13I got contacted by Sharon and Big Mike.... Thank you po sa inyo dalawa. I will be there last week of May so Expect me to pay you guys a visit to see the options I have. Thank you din po sa mga nagreply.
- 44
May 7th, 2008 07:14 AM #14
high idle RPM at engine start
