last week dinala ko sa nagre-repair ng muffler, chineck nila wala naman daw singaw, tinest drive namin, tapos may naririnig parang singaw na pasumpong sumpong. so tinanggal yung pipe na nakakabit sa ilalim ng exhaust manifold, papalitan sana ng gasket kaso iba pala ang gasket nito, parang donut na nakapasok sa loob. wala daw silang makukuhang ganung gasket. ang ginawa nila nilagyan na lang ng silicone tapos ikinabit ulit. nung tinest drive namin nawala. pero nung pauwi na ako, narinig ko na naman. pasumpong sumpong na naman. pero mas naging ok na ang hatak.
meron pa ding kaunting singaw na paminsan minsan, tinry ko din ipa-check sa ibang mechanic, ang sabi try ko daw palitan nga yung gasket at sabi niya baka daw lost thread na yung turnilyo nanagko-connect sa exhaust manifold at pipe sa ilalim. kung ganon daw ay baka i-machine shop.
medyo nakakapagod din.
In your case, talagang nakakapagod nga. It might had misaligned the matings of the lower connections to the muffler during removal of your exhaust manifold (proper removal procedures might have neglected). But your persistence of having the car to be on its top performance, give you results to determine where & what the problem of your car. Since you had observed, where and what have caused ang paghina ng hatak at pagsingaw na nararamdaman mo. Sa magaling na muffler & exhaust system ka magpagawa bro.
Sent from my UP+ using Tapatalk
You got this far of guessing and hoping but there is no mention of checking engine intake manifold readings. Taking the scenic guess and hope approach makes it longer
https://m.youtube.com/watch?v=SdlNwm8OHco
iniisip ko na lang nga kung palitan ko na lang yung buong headers. kasi yung naglinis ng oil pan gasket wala daw siyang makuhang gasket para don sa ilalim ng headers connecting the pipe.
mga sir, ma-solve kaya ang issue na ito kung bumili ako ng bagong headers? ok ba yung ninja 4-2-1 headers?
How old is your civic? Stock exhaust system pa rin ba? Just a tip. One of the few things mostly replace parts in an old vehicle aside tuning its engine, is replacing the old stock exhaust system. Once replaced with a new one(OEM type), you may feel a big difference in performance and good fuel mileage.
Oops! Be sure na fit eto sa model mo. May kamahalan nga lang kung magpapalit ng buong exhaust system (OEM type). Pero sulit naman. Sa FC, titipid. Sa HP or performance, talagang ma-feel mo ang difference after changing it. Sa arangkada at rekta na takbuhan.
Ang mga pwede palitan, exhaust manifold, headers, flexible connector pipe (kung meron), center muffler and muffler(end).
