Results 1 to 10 of 56
- Dec 2011
- 70
July 26th, 2015 08:37 AM #1mga sir, ask ko lang kung ano problem ng civic ko kasi after palitan ng oil pan gasket, pabago bago yung hatak ng sasakyan.
parang may singaw kaya hirap humatak, may kaunting ungol at parang sipol sa dulo pag tumataas rpm. sabi ng mechanic may singaw daw sa tambutso, palitan ko na daw yung metal gasket. Ito nga kaya problem non mga sir?
- Mar 2014
- 901
July 26th, 2015 04:03 PM #2Nagpalit ka lang oil pan gasket, nagkaron na abnormalities sa performance. Pero before it was done changing gasket, normal at no abnormalities in driving performance? Maybe I will be more concern in checking the area of the oil pan, where the gasket was replaced, checking and looking for any possible leaks of oil. Kung yung lang naman ang ginawa, dapat wala kang issue na ganyan. Humina hatak? Syempre nag-change oil ka na rin nyan dahil, nai-drain yun oil, para ma-remove yun oil pan. Ang lastly, pinalitan mo na rin ba ang oil filter mo?
Sent from my UP+ using Tapatalk
- 52,724
July 26th, 2015 04:07 PM #3That should be easy to verify.
Have the car lifted or crawl under it. See if there is exhaust gas leak. Tingin rin sa engine bay if the exhaust manifold is ok.
July 26th, 2015 06:54 PM #4
Waste of time. Run the engine and have somebody with good hearing listen for sound intensity. Kung sumisipol na ang exhaust system restricted ang catalytic converter. Kung may sumisipol bukod sa exhaust, may posibilidad na intake vacuum leak. A simple engine vacuum at idle will tell you and the coolant temperature will slightly be elevated together with engine knock with engine warm
- 52,724
July 26th, 2015 07:04 PM #5Errr... How is engine vacuum determined, and how elevated is slightly elevated?
Inquiring person / TS appears to be a noobie...
- Dec 2011
- 70
July 26th, 2015 07:07 PM #6before palitan ang oil pan gasket ok naman ang takbo at hatak, ok naman performance nung kotse.
humina ang hatak after palitan oil pan gasket, tapos may naririnig pa akong ungol ng makina pag tumataas ang rpm.
hindi ko pa pinalitan oil filter.
pa-check ko bukas sa ibang mechanic sa gas station para may lifter, baka papalitan ko na din ng metal gasket yung exhaust manifold.
sana nga mga sir yung lang ang problem. may time din na medyo tumitigas yung gas pedal na dati namang malambot at smooth tapakan.
- 52,724
- Dec 2011
- 70
July 26th, 2015 07:27 PM #8
- Oct 2009
- 2,271
July 26th, 2015 07:38 PM #9pag nag palit kasi oilpan gasket binabaklas din ung exhaust diba baka hindi maganda pagkaka balik kaya may singaw..
July 26th, 2015 07:42 PM #10
[QUOTE=dr. d;2578883]Errr... How is engine vacuum determined, and how elevated is slightly elevated?
Inquiring person / TS appears to be a noobie...[/QUOTE
Install a vacuum gauge to a non-ported vacuum source( one that is behind the throttle plate such as the brake vacuum booster hose) and observe the reading (17-21 inHg) at idle, if it is out of range, there might be vacuum leak at the intake. Since you did not use a thermometer to measure temperature and since more than likely you glanced at the instrument cluster or the driver information panel, you must have taken note where the pointers of the gauges stay or if you have a digital cluster it must have given you numbers.
Before I sold my 2005 Innova after 12 years of heavily using it, I never changed its water pump.
