Results 1 to 10 of 13
May 14th, 2013 07:33 AM #1
Magandang umaga mga sirs.. Patulong naman regarding sa PCV Valve ng esi namin.. We haven't changed or replace the part ever since na bili yung sasakyan noong 1995, meron bang mabibili na PCV valve at magkano? Thanks in advance..
- May 2005
- 56
May 17th, 2013 02:22 AM #2any auto supply should have that.
kung gusto mo, tanggalin mo then show the part sa shop
ingat lang, minsan nagiging britlle yung PCV na yan, na pag tinanggal mo eh pwedeng mabasag/madurog at may maiwan na small parts sa loob ng pinagtanggalan mo.
cost? around 100++ pesos
- Jul 2012
- 329
March 25th, 2016 10:22 PM #4sir i have honda jazz 2005 1.5vtec matic engine. car roughly idles lalo na kapag on aircon. rpm sometimes drops beyond normal which causes the engine to jerk or even stall. sparks already replaced, TB with IACV already cleaned, replaced one suspected ignition coil damage but still same issue. nabasa ko a faulty PCV can also be the cause. I checked the spot kung san located PCV Valve ang daming carbon buildup. planning to replace it DIY lang. what you think mga sir?
March 25th, 2016 10:46 PM #5
- Feb 2003
- 1,038
March 26th, 2016 09:11 AM #6Your car symptoims is very similar to my 2nd gen CRV diagnose fault code is TPS error. Replaced it and now back to normal again.
March 26th, 2016 09:33 AM #7
kakabili ko lang ng pcv valve a month ago para sa civic fd 2.0 namin kasi sabi ng mechanic ko medyo malutong na daw siya at malapit na palitan. kung tama pagkaka-alala ok it cost me something like P500+ sa casa.
- Jul 2009
- 2,618
March 26th, 2016 09:59 AM #8Agree with sir jick. Usually may stored trouble code ang pcv or tpms malfunction if not may check engine light pa. Avoid guessing and unecessary expenses have your car scanned first. Any repair shop worth their name in salt should have an obd scanner as it is inexpensive
April 25th, 2016 07:05 AM #9
- Aug 2015
- 109
June 22nd, 2016 08:41 PM #10mga sir magpapalit din ako ng pcv valve, okay din ba ang quality kung sa mga auto supply ako bibili? tama po ba na may kasamang o ring at hose ang pcv valve? tia
I am happy for you. We had a very bad experience with VW Philippines. We will avoid getting from...
China cars
