Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    Jul 2006
    paano po magreset ng ecu ng honda civic vti 1996?
    tanggal lang battery for 30 minutes, imho.
    Sep 2004
    You can also try removing the ECU fuse sa fusebox (for at least 5 secs) in the engine bay.
    May 2007
    Unhook your battery cables and touch them together for 1 minute! (there will be no power in them so dont worry) and then hook them back up !! if the light comes back on you still have a problem which I can probably help you with that also!! When you touch the wires together what it does is drains the memory on the computer, then when you start it it will take about 10 minutes for it to finish all of its tests and have everything set just right!!
    This source is came from a retired master mechanic which we apply this in my friends Toyota celica.
    Jan 2009
    Bakit ba nirereset ang ecu??
    pde ko ba ireset yung ecu ng kotse ko for better performance??
    wil it harm my car??
    Sep 2006
    Quote Originally Posted by sohc_teejay View Post
    Generally, it won't harm your car. It is usually done after doing performance upgrades like better intake etc.
    Mas advisable punta ka sa kasa kasi my ecu have diff. Versions try mo lang mag ask dun d2 kasi sa thailand sa kasa yun nirereset at upgrade ng version
    Jan 2009
    Quote Originally Posted by 1D4LV View Post
    exactomundo! hindi kailangan 30 minutes.. pero bakit po kailangan reset? logically wala pong babaguhin sa performance pag nareset ka ng ECU.. Sobrang talino po ng ECU ng honda. Very little changes or upgrade eh narerecognize na ng ECU. So why reset?
    Jan 2009
    kung sa ibang oto pla kelangan?? pero with honda... hindi na?
    any change done to the engine, its advisable to reset the ecu. simple lang naman to do. tama! just remove the battery terminals for a minute or two. ok na.
how to reset ecu
