Results 11 to 17 of 17
January 25th, 2009 04:40 PM #11
remove neg terminal, crank the engine twice, presto ecu reset, no need to wait for minutes/seconds.
Resetting ECU is a must after making changes in your present set up or when doing engine performance tuning, like remapping ECU using crome, uberdata, hondata, et al, adjusting vtec engagement point, fuel management, target idle, speed/rev limiter, air fuel mixture ratio, et al.
Why? so that when you start the engine the ECU is already running the remapped program. When ECU was reset the new tuned program is readily visible at your laptop unlike when it is not reset you have to wait for minutes/hours before the new remapped program takes effect in accordance with your tuning program.
- Nov 2008
- 18
January 28th, 2009 09:44 AM #12
- Nov 2008
- 18
January 28th, 2009 09:45 AM #13
- Feb 2007
- 74
January 31st, 2009 07:17 PM #14mga bro,
paano reset ecu ng crv gen 2? kasi super bagal yung matic ko, grabe. lakas pa sa gas
tia
February 4th, 2009 05:42 PM #15
bro, ung civic ko 05 model . naka freeflow mufler at simota filter, kailangan ko pa ba ipa adjust ang ECU sa honda service center?? hindi ako masyado familiar regarding sa ecu..
- May 2010
- 13
June 4th, 2010 06:21 PM #16up ko lang ito...
am thinking of resetting the ECU of my '96 LXi...lakas sa gas pag city driving eh...just remove battery, right?
- Oct 2009
- 2
June 5th, 2010 02:26 PM #17ph16a vti? obd2? panu maaafect ang ari fuel ratio if not tuned or rechiped?
Cabin Air Filtre Carbon activated, interchangeable with 27277-4JA0A/B P190 only. Almost P3k ito...
Nissan Navara NP300
