Results 1 to 7 of 7
    Feb 2011
    good day po..anu po kaya problem ng car ko dati kasi pag nag N position ako ng shift nag start naman siya pero ngyon di na as in wala talaga pero..pero sa P ok naman..
    naisip ko baka ignition switch,sileniod plunger,or automatic renge switch tama po kaya..
    Dec 2007
    why do you need to start your a/t car at N sir? di ba risky?
    +1 plus one of his question, bakit ka sa N nag start ng kotse? hinde mo maaalis yun key sa ignition pag wala sa P diba? kahit kailang never pa ako nag start sa N....anong incident na sa N ka nag start, hinde naman namamatayan ang matic unlike sa manual pag mali timpla
    Jan 2011
    Quote Originally Posted by atog View Post
    nag start ba kung nasa (P)? if yes, wala kang problema. if i were you, i will not treat matic like manual. it was manufactured and designed that way for a reason.
    Feb 2011
    read your owners manual..naka lagay sa instruction n P and N position ay pwede mag start engine..ginagawa ko to palagi ever since pa..ngyon lang di na gumana..maski sa honda fd nmin nag start din sa N position..
    I am thinking the safety "switch" could be defective in the N position. Similar to my mom's FD, it wouldn't start at all but shifting up and down the A/T level a couple or so times lets the car start normally.
    May 2004
    yeah P and N pwede mo start. now the question is bakit mo gusto mag start sa N? wala kasi kami makita reason aside from trip or troubleshooting lang.
    although i agree with GH. yung saftety switch baka di gumagana sa N. try to browse toyota AT manuals. meron ako kaso di ko na tanda so ko nadownload sa net. its like me continuity lang ang starter when the lever is at P and N. baka nawala yung continuity sa N. hth
honda civic vtec3 A/T not starting on N position
