Results 1 to 2 of 2
- Apr 2011
- 44
May 10th, 2011 10:47 AM #1[SIZE=3]Ang problem ko ay sa manubela ko.. bakit kaya pag nasa cement road ako nagwiwigle ung wheel merong kabig... napalitan ko na 2 ball joint lower part... ano root cause nito?... thanx in advance mga tsikoters.. san po kaya mura magpagawa d2 sa sta. rosa, laguna?
[/SIZE]
- Jan 2011
- 317
May 14th, 2011 02:19 AM #2steering will shake if your wheels are not properly balanced. it usually occurs when you are running above 100kph. with regards to kabig problem, make sure your wheels are properly aligned. these two issues will cost you more fuel consumption as well as improper tire wear, and suspension problems.
When does that happen? 1. During starting? 2. While the vehicle is idling/running?
ALTERNATOR. Repair or replace?
