Results 621 to 630 of 1000
- Aug 2016
- 26
August 22nd, 2016 11:38 AM #621
try mo dito mga Chinese versiion. Meron Taobao Agent sa makati, where you can buy anything from that site and let them help you ship it to Manila via Balikbayan box. Usually stuff arrives in 2 weeks with them. Taobao is owned by Alibaba, and that website is very known in mainland China.
?????????APP_????
- Aug 2016
- 2
August 24th, 2016 10:33 AM #622same case here. i get the grating sound while pressing the brakes. then while in drive, in low speed, not pressing on the brakes, the sound is high pitched squeal. the sales agent said its normal when you have passed flooded streets. i think it's affecting fuel consumption.
- Dec 2011
- 37
September 5th, 2016 01:20 AM #623Maybe this link might give you some insight
Squeaky Brakes | Brake Squeal | Brakes Grinding | Pep Boys
- 22
September 8th, 2016 10:33 AM #624Good day sirs. Just noticed my mobilio 1.5 V CVT, the letters on the shifter lever does not illuminate at night when I turn on the head lights. Same as the auto window switch on the driver side. I called honda and asked about the matter and they said it was normal with mobilio as everything is basic.
Also noticed the rear wheels have negative camber. This would cause uneven wear on the tyres.
- 54,272
September 8th, 2016 10:42 AM #625have the camber checked, po, using camber measuring equipment. it's sometimes easy to be fooled by the eyeball method. but you can probably ask the casa to check them, on your check up. give them a call, po. it's supposed to be free, this early.
about the night illumination naman, let us wait for the other users' inputs. maybe the casa is right, maybe they are wrong.
but... because it is more expensive to re-tool in manufacturing, they sometimes already have provision for easy upgrade. aka, the necessary holes and mounting paraphernalia are already there. maybe someone can open her up and put in the bulbs, to activate them.
September 8th, 2016 10:48 AM #626
Some cars are designed with wheels that are offset positively or negatively ... Example would be the Mazda 3, to increase the steering feedback, the front wheels are offset about 6 degrees ... Also rear wheels usually have negative camber to have better grip when cornering ... So when adjusting wheel alignment make sure the equipment has settings for the exact year, make and model of your vehicle ... different cars have different settings ...
September 8th, 2016 12:54 PM #627
Most hondas (if not all), have negative camber sa rear. Normal yan sir. Uneven wear - unnoticeable yan sir, parang wala. Unless siguro di ka susunod sa recommended interval ng tire rotation. Also, you cannot adjust the camber without buying camber kits AFAIK.
Sent from my D6503 using Tapatalk
- 22
September 8th, 2016 05:30 PM #628Thank you sirs for the feedbacks. I have seen some mobilios on the road and parking lots. All have the same negative camber.
As for the nil illumination for the letters on the shifter, hopefully other owners would verify if they have the same
September 8th, 2016 07:29 PM #629
- Jun 2006
- 188
September 9th, 2016 07:47 AM #630+1. Nanibago rin ako nung una. First time that i had a car na walang illumination sa A/T shifter as well as the window switches.
Nasanay narin lang but it is frustrating for other passengers who are unfamiliar with the car and would want to open the windows at night.
Naintindihan ko pa ang shifter, because meron namang display sa dash (and you won't really look down din naman sa lever while shifting).
up for suzuki
Let's keep our Chapter Alive! ATO NI Mindanaoans!
