Results 1 to 10 of 1000
Threaded View
February 9th, 2017 11:04 AM #11
If that is the case, I am guessing (here that) it is not the battery but the idle/sleep/standby current of the car (and its accessories).
Can someone get a multimeter and set it to DC Current?
Disconnect the car's battery cable from one terminal of the battery and connect it(cable) to one of the multimeter's probes,- and the terminal of the battery to the other multimeter's probe. Close the door, turn off the lights, radio etc and lock the car using your remote control,- then measure the current. It should be below 100mA. If not, what do you measure?
If for example you are measuring 250mA,- then you're draining 1A-Hr every 4 hours,- not healthy.
Batteries though are rated typically at 40 A-Hr (not sure about the Mobilio battery). But if you park it for 24 hours at that drain, then you lose 6 A-Hr already and the battery may become weak much earlier over time.
_/_/_/
31.8K _/_/_/_/_/_/_/_/_/_/
Imo at that price it becomes a very tempting buy even with its' flaws.
2021 Nissan Leaf
