Results 1 to 10 of 21
- Sep 2013
- 375
November 6th, 2013 12:48 AM #1Hi guys I own a honda fit GD from japan with 120k na sa odometer.Kadalasan sa expressways dun nag bblink ang "D" then hirap mag shift na parang 1 gear lang.Hindi na rin pala smooth takbo ng GD ko pero walang malakas na jerk o nginig. Guys CVT na kaya to? Do you guys recommend buying surplus tranny kaya?
Thanks po
November 6th, 2013 09:03 AM #3
I think it is starting to act up...
Better have it checked, bro.
21.5K:toothbr1:
- Sep 2013
- 375
November 6th, 2013 06:08 PM #4Sir robot, not yet boss i think hindi pa naman madumi yung cvtf pero dinagdagan ko siya last month. Na sosolusyunan ba ng change cvtf yang mga ganyan boss? Thanks boss
Sir CVT, sabi sa honda spa hindi daw nababasa ng mga computer nila ang mga galing japan
Try ko sa honda alabang boss
November 7th, 2013 06:24 PM #5
Meron ng ganitong issue (CVT) dun sa isang thread ah (Second Gen Honda Jazz/Fit). Anyway, I'll share my wide experience on my GD-CVT.
Twice na ako nagpalit ng tranny, first time ko naramdaman yung problema during our way home from Antipolo. While traversing the highway, bigla na lang nag blink yung "D" ko and then nararamdaman ko na humina yung hatak nya. Imagine, nasa 5000rpm ko pero ang takbo ko 30kph. I've decided to pull over in one of the gasoline station to check the manual while letting the engine rest. Nung start ko na, mejo bumalik sa normal condition so ang akala ko okay na but nag research pa din ako sa net ng preventive action and according to some GD owners, you just need to add/replace the CVT fluid, which I did. Almost 1 month wala ako nararamdaman na problema then suddenly, bigla na lang hindi gumana tranny. As in wala talagang abante, pero may reverse. I did everything to resolve the issue to wit; change oil, spark plugs, brake fluids and CVTF but to no avail. Dun ko lang nalaman na talagang wala na pag-asa kaya I've decided to replace the whole tranny.
Second time, ganun din. Nag blink yung "D" and then nawawala din pag shut-off then start. After a week, ayun! itinirik ako sa gitna ng macapagal and buti na lang naramdaman ko dahil nasa third lane ako pero naitabi ko pa din sa gilid habang naka umaandar pa siya.
Suggestion ko lang sayo. Wag ka lalabas ng bahay with less the 5-10k ang dalang pera dahil worse na pwde mangyari talaga sayo is itirik ka sa gitna at ma-tow and matiketan pa. Another thing, stop using the 7 speed mode dahil yun ang malakas makasira. Feeling mo nasa 2fast 2furious ka ba? He,he.
- Sep 2013
- 375
November 7th, 2013 06:33 PM #6boss medyo konti lang kasi reply dun hehe hindi masyado pinapansin.Sir 2nd owner na ako nakuha ko 120k ang odometer so ako naman maingat talaga ako sa kahit na anong sasakyan,hindi humahataw at di ko ginagamit yung 7 speed mode .Sir sa tingin niyo Tranny na talaga ito? and kung surplus tranny ba tatagal siya? or better change the car? kamusta na GD niyo sir. thanks for your reply sir
November 9th, 2013 09:07 PM #7
^ kung may budget siguro para peace of mind palit car ka nalang. pero just in case pa member ka na din sa AAP in case need mo ng towing mas mura.
- Sep 2013
- 375
November 10th, 2013 12:16 AM #8
- Jun 2013
- 5
November 10th, 2013 02:25 AM #9Share ko lang, I own a Honda City Idsi.CVT din. iba nmn ang case. saken nakalog ang buong makina pag nasa reverse tsaka may jerking pag nakamenor. at minsan ayaw na tlga umatras parang bumibitaw ung reverse ko. Nagpalit ako ng tranny last month lang. sa banawe. okay naman. kung gsto mo pa isalba ung GD mo, try mo muna mag change ng Tranny fluid, pero kung gsto palita ng tranny. pwede din. Swabe naman ngayon ung takbo ng kotse.
- Sep 2013
- 375
November 10th, 2013 02:21 PM #10
- recommended TP per manual is 35 psig, should be fine. - it's good to play the drive settings...
2023 Ford Everest Owners Thread
