Results 1 to 7 of 7
April 4th, 2013 01:54 AM #1
Latest Testimonial on Honda Fit/Jazz/City, Transmission Shudder
Gidday George,
Just a quick note from New Zealand with a bit of feedback. We bought Oil Extreme after reading good reports of its ability to help with the CVT gearbox shudder that sometimes afflicts older Honda Fit (Honda Jazz). We had tried a full CVT oil flush (expensive!) in our 2006 Fit, which didn't fix the problem. So I tried your little bottle of magic additive. A drive around the block and no more shudder - I was amazed! 10,000 km on, and still no hint of a shudder.
Thank you George for your great product, and for your phone call and fantastic service.
Kindest regards,
Niall
"After being quite skeptical, I added the oil extreme concentrate Wednesday evening to the CVT Fluid in my little Honda FIT, and yes, it worked! No shuddering since then. The Honda is one of those with a GD1 number and I had this shuddering problem since more than 4 years, spent a lot of money on original CVTF oil from Honda and the shuddering never really vanish completely after any of the servicing. If the shuddering doesn't come back, your product would be really amazing, especially due to the fact that Honda couldn't solve this issue! Thanks so much."
Cheers,
Stephan
Oil Extreme Additives for Diesel/Gas Engine Philippines - 9267143
Honda Car Onwer Meet Up buyers... | Facebook <user of honda cars>
- Apr 2013
- 3
April 11th, 2013 01:46 PM #2Hi good day so this oil you simply add to your CVT oil to remove the shudder? Kindly help.. The Honda Jazz we are using is experiencing transmission shudder and we had these parts changed.
Crank Position Sensor 3,500 php
Drive Pulley Sensor Tranny 2,800 php
Reverse Solenoid Valve Directional 2,500 php
Thanks!
April 11th, 2013 02:42 PM #3
Yes sir lagay lang po kayo or mag add ng Oil extreme sa CVT fluid sigurado makakatulong ito na maayos yung transmission shudder nyo...hinde nya gagawing malapot yung CVT fluid gaya nung ibang addtives kaya safe na safe po ito sa tranny nyo...sir bago po kayo mag palit nga mga piyesang nasabi nyo try nyo muna mag lagay nito tutal parang papalitan nyo na rin yung mga nasabing parts nyo kung baga last resort bago tayo magpalilt para hinde lumaki ang gastos...
- Apr 2013
- 3
April 11th, 2013 05:19 PM #4
April 11th, 2013 05:40 PM #5
wala naman po sigurong tagang presyo basta pulido at maayos ang pag kakagawa sa mga investment natin...
Oil Extreme Additives for Honda Jazz/Fit/City Transmission Philippines - 9267143 <<<click nyo na lang po ito para kung saan nakakabili thanks po...
May 29th, 2013 05:39 PM #6
May 31st, 2013 04:45 AM #7
check the the buyers http://www.facebook.com/media/set/?s...1485677&type=3
high idle RPM at engine start
