Results 1 to 2 of 2
    Mga Sir patulong naman po sa problem ko regarding my 2005 honda crv.
    -Nagloloko po kasi yung menor ng crv ko, for example umaandar ako tapos nagminor or full stop tumatas po yung rpm for about 1500k to 1800k. Diba po dapat balik siya sa normal idle na 900 pag ngbreak ako at tumapak sa clutch. sopecially po kapag mga biglang stop tumaatas siya chaka pagpaliko ako tapos tinapakan ko clutch. hindi po siya katulad nung ibang problem na nagdadrop yung menor. possible din po kaya sa iacv ang problem nito?
    -kapag nakmenor po yung car tapos kinabig ko manebela gumagalaw po rpm without stepping on the gas, tumataas ng 200 to 300rpm. normal lang po ba to sa crv?
    Mga Sir kailangan ko po nang tulong nyo please, lalo kasi mas malakas sa gas yung crv hehe...
    Feb 2005
    Dati pa bang ganyan? Pa check mo sa casa para madiagnose. Baka Throttle Body cleaning yan or kailangan na i tune up, maraming pwedeng causes. Hindi normal yung ganon unless di pa siguro warmed up yung makina. Try to disconnect the battery for about 10mins then reconnect it to reset the computer let it idle until it warms up/aux fan engages then drive it as per usual and see if it still happens.
    Things to consider:
    1) When did it first start happening or when was it noticed?
    2) What was the last service done and when was that done?
    3) When does it exhibit the behavior, is it constant or does it come and go?
    Let us know how you fix this.
Honda CRv idle problem
