Results 671 to 680 of 1220
- May 2015
- 16
May 30th, 2015 11:55 PM #671Looking for a tonneau cover for crv 2008 saan kaya meron? Mura sana sa ebay talo lang sa shipping
- May 2011
- 227
May 31st, 2015 12:37 AM #672
- May 2011
- 227
May 31st, 2015 04:24 PM #674Sir napacheck ko na po sa aircon shop kung un tunog ba is coming from compressor or bearing ang sabi sakin Hindi daw compressor o bearing baka support which is di na nila handle pacheck ko daw muna sa mechanic para maconfirm saka di siya natunog kung AC lang open pero pag pati mga ilaw bukas dun na natunog
- May 2011
- 227
May 31st, 2015 11:24 PM #675Does anyone knew kung how much is the diagnose or check up in Honda spa? Saka need ba appointment or pwde walk in? May nakita ako sa site nila mga promo basic tune up at free 25 point check
- Jun 2008
- 1,741
June 1st, 2015 07:38 AM #677
- Oct 2014
- 2
June 1st, 2015 09:35 AM #678Hi Tsikoters
Need your assistance.My V wont move or budge after starting the engine even if my parking break is disengaged.
My garage parking is 15 degrees downhill and normally I just disengage my parking break then I am off. Today after 3 weeks of not using my V it just won't move as if there something stopping the wheels.
I already tried the following:
a. Press down the clutch to the floor change gear 1 and reverse still wont budge
b. Started engine on gear 2 and 3 still nothing
Here is what I suspect my break got stuck or sticking. I want to get it cleaned however the challenge is getting to nearest aunto mechanic and the car won't move. My question is do I let the break bleed then bring it to a nearest shop to get it cleaned? or Will it be possible for a home service mechanic to get the break cleaned or does it need to be hauled to a shop to get it fixed? Anyone who have done a DIY?
Any inputs are much appreciated. Can guys suggest a mechanic near MCI Imus, Cavite? TIA
Admin, I am not sure if it should be posted here but feel free to move it the right forum location.
PS. My V is MT 2nd Gen (2003) and 2WD variant.
-SW
June 1st, 2015 10:41 AM #679
Probably stuck parking break. Move it back and forth. Check tires if they have enough air.
- Oct 2014
- 2
June 1st, 2015 10:50 AM #680Hi Walter,
Tires are ok, Should I press more gas while on reverse and force it? The parking break lights are off when I disenage, is that possible the parking break is still stuck even it the warning lights for that are off?
high idle RPM at engine start
