Results 441 to 450 of 1220
July 20th, 2013 05:18 PM #441
July 25th, 2013 01:36 PM #442
Mga sir, malapit na ang change oil ng aking CRV. 2008 model, 2.0L engine. Saan ang magandang kuhanan ng oil filter and gaano karaming oil ang nagagamit per oil change? Dito po ako based sa Batangas.
- Jan 2013
- 12
August 5th, 2013 09:29 PM #443Hi! I have a 2008 crv 4wd... it just recently hit the 50k mark... problem is may scratching sound for 2 secs after starting the car. Sure naman ako na hindi matagal pag hold ko sa start para mag cause ng ganung sound. Nangyayari lang siya pag cold start, yung more than 8 hours di nagamit yung car... pag may ganun ako na nadinig usually pinapatay ko uli yung car then start ko pero wala na ko nadidinig... i am not sure what the problem is... hope you can help me guys
August 6th, 2013 10:43 AM #444
Mga bro, ayaw magstart ng aking CR-V sa park position pero kapag naka-neutral eh ang bilis magstart. Ano kaya ang problema at paano aayusin? Thanks! 3rd gen CR-V btw
- Jun 2013
- 120
August 6th, 2013 11:09 AM #445Sabi dito Honda CR-V Questions - CRV won't start in P - CarGurus DTRS ang problem at pwedeng cause pag binaha or muddy ang ilalim ng vehicle.
August 14th, 2013 10:54 AM #446
August 14th, 2013 12:11 PM #447
August 14th, 2013 01:01 PM #448
Natuklasan ko na kung paano baklasin yung bulb. Problem is malaki yung nakuha ko, H4
Anong size nung bulb para sa low-beam? Hindi ko kasi alam kung H1 or H3 yun eh. Kaya pala mahina ang ilaw ng low-beam kasi maliit ang bulb. :twak:
- Jun 2011
- 25
August 21st, 2013 12:16 AM #449For the Thai version 2013 CRV, is there a big difference on power and FC between the 2.0 and 2.4? Has anyone used the removable 3rd row seat? Any reviews? Is Bluetooth for hands free telecom available in this CRV? Reverse sensors? Reverse camera?
How come the Malaysian CRV 2.4 is listed as having 190 PS while the Philippine version is 185 PS? Is the Malaysian CRV a new model? Or is it a function of type of fuel used? Btw, what kind of fuel (octane level) is used for the CRV? Will using Euro 4 or PETRON 100 be advisable?
August 21st, 2013 12:40 AM #450
Hello 2010 2.4 model owner here . Nasubukan ko na idrive both 2.0 and 2.4 and malaki talaga power and FC difference. In my own experience, mas maganda FC ng 2.4 kaysa sa 2.0L. Mabigat kasi CRV kaya medyo underpowered siya sa 2.0 engine. Same lang naman din to for the new CRV since same engine lang naman although may Eco feature na ung bago. Mixed city driving FC ko for 2.4 is 8.6km/l while highway naman is 13.8km/l
Sa features naman, di ko ako sure kung may reverse cam and sensors ang thai unit, better check their website for complete info.
I use Petron's Blaze since un na lang ang ethanol free gasoline sa pinas. Di ko nagustuhan performance ng XCS 95 nung nagsimula magkaroon ng ethanol content. Lakas ng vibration saka mahina humatak.
high idle RPM at engine start
