Results 1 to 10 of 62
- Mar 2013
- 1
September 9th, 2018 08:29 AM #1Im also having the same exact problem with my 3rd Gen CRV. On idle, my rpm is at 500 only(with or without AC). Engine also vibrates strongly everytime the AC Compressor kicks in but the vibration will disappear when the temperature of the engine reaches half of the gauge. Does the vibration on your crv disappear also after a certain period of time?
I never had the chance to have this idle issue checked by a mechanic because i thought it was just normal? But looking at the previous replies, my idle rpm should be at 700, right?
Question:
Are there any bad effects on the engine if i continue to run it at low idle rpm?
- Sep 2018
- 1
September 10th, 2018 04:59 PM #2Hi Sir Szekan,
tanong ko lang kung saang shop nyo pinagawa yung Bushing ng EPS Rack N Pinion nyo?
issue din kasi ng FD ko yan palit na lahat ng pang ilalim pero kalampag pa din. yun pala yung pinaka Bushing ng Rack N Pinion problema. wala ako makita gumagawa. hassle tong EPS
Salamat sir!
- Nov 2018
- 27
November 7th, 2018 09:57 AM #3
- Nov 2018
- 27
November 7th, 2018 11:59 AM #4
- Nov 2018
- 2
November 9th, 2018 04:41 PM #52007 crv 4x2. Bigla na lang umilaw ang airbag light. Ayaw na mag function ang speed lock, seat belt reminder light at chime.
Sa mga naka encounter na ng ganito sa crv. Saan ninyo pinagawa?
- Mar 2015
- 12
November 9th, 2018 05:18 PM #6
November 9th, 2018 05:32 PM #7
If it's the seat weight sensor that detects being sat/occupied, the hobo route would be to bypass w/ SRS fooling resistors.
Sample:
HONDA 2.7 OHMS OHM SRS AIRBAG RESISTORS RESISTOR .25W 2 AMP FUSED FAULT LIGHT | eBay
- Nov 2018
- 2
Buti nalang hindi binintang yung kotse since hindi naman siya monterosport. It would be different...
