Results 1 to 12 of 12
    May 2011
    Good day po!
    Recently nag pa install po ako ng car alarm sa CRV ko (model 2004). Then after a day or two, I noticed medyo hirap na mag start yung auto ko. parang ganito pag mag start... "tsug-tsug-tsug-broom.....". usually "tsug-broom...." lang. minsan abot hangang 5 na tsug!
    I searched through google and found na nakakaapekto nga "daw" sa battery yung alarm sa car (not sure if true though). Tanong ko lang po kung may naka experience na to sa inyo. Otherwise, pa tangal ko na lang ulit yung alarm (sayang medyo mahal pa naman nung alarm nasa 3.5K )
    Salamat po!
    It is possible that the installer has accidentally grounded the battery causing it to loose its charge in a day or so.
    To test, have the alarm disabled and have all the wires added for the alarm checked.
    In short, bring back to the installer to have his work checked over.
    Jun 2010
    tama si papa GH..grounded yan.. happen to me also with my old toyota..nun di pa ko nagpapakabit ng alarm ayus naman lahat... nun pinalagyan ko ayun... nakapark lang maghapon sa bahay drain yun battery
    May 2011
    Oo agree ako dito na grounded nga yan. Sayang battery at oras sa ganyan.
  5. #5
    Quote Originally Posted by wic View Post
    Good day po!
    Salamat po!
    I read the situation but its not about drained battery is the problem, kase nag start yung engine e, the problem is hard starting the engine, if i guess that, naglagay ng immobilizer yung installer and the relay used was loosing power to start the engine very quickly, you can test that by arming your alarm and try to start the engine, if there is redondo while starting the engine, the installer cut the ignition wire, if just a click while starting, the installer cut the starter wire and that is the right thing doing an immobilizer.
    If your battery was the problem, your engine won't start unless you do jumpstart from the other source of power supply, and because we see clearly that you had these problem pagka install ng alarm, ang problema ay sa relay ng immobilizer na nilagay nung installer, maybe an error of electrical wiring and connection na dapat ma check kaagad.. have a nice day..
    May 2011
    pina disconnect ko yung alarm, nakauwi ng bahay yung auto, then the next early morning.... ayaw na mag start yung auto!
    purchased in early 2009 yung battery (motolite). di kaya problema na sa battery ito? or kelangan nang mapalitan ng bago?
    Dec 2007
    baka naman nagkatoon lang sir kasi if ever discharge ang battery "tik tik tik" and tunong sa start.
    para maka sure patignan mo na lang din uli dun sa nagkabit ng alarm then pa check battery...
    grounded or you need a new battery
    Maybe just coinsidence that your existing battery was dying when you had the alarm installed.
Car alarm draining my CRV's battery
