Results 11 to 19 of 19
August 29th, 2010 08:20 AM #11
August 29th, 2010 10:03 AM #12
- Aug 2010
- 13
August 29th, 2010 03:05 PM #13Typo error sirs, my honda SIR is 99. mataas rpm ko pag nag shift ako from 1st to 2nd kasi pag mababa para syang mamamatay, same with 2ndto3rd, as in kailangan patagalin ko in 2nd to raise the rpm,hiraptalaga sya bumatak. any help will be greatly appreciated... thanks masters...
August 29th, 2010 05:31 PM #14
AFAIK late 1998 ni-launch ang SiR with an introductory price of P618,000. Available colors were Passion Orange, Night Hawk Black and Tafetta White.
Late 2000's Passion Orange color was discontinued.
2001 introduced two new colors, the Sunburst Yellow and Formula Red. Now the price increased to P728,000.
*wiggle71, try to check if you have exhaust leaks. A worn out exhaust gasket near the exhaust manifold might be the cause of the lost power at lower rpms. Not so sure about this. Update us nalang. HTH
August 29th, 2010 05:48 PM #15
So pag naka idle, di naman sya namamatay? sa 2nd & 3rd gear lang me problem? weird acutally...
Kung fuel supply dapat consistent ang problem with all gears, kung tranny naman since manual yan usually bumibitaw lang ang kambyo if bearing ang sira or sliding ang clutch.
Any Mods done ba?
- Aug 2010
- 13
August 29th, 2010 10:53 PM #16no mods done sir, and pag naka idle ok naman engine. it's just during shifting to 2nd gear talaga, kahit galing sa mataas na rpm biglang babagsak rpm ko then tagal kong babatakin para tumaas rpm for 3rd gear. might this be a timing problem? kakapalit ko lang clutch components.
thanks for any help you can extend mga masters.
- Oct 2008
- 656
August 29th, 2010 11:13 PM #17sir mahina nga ung pangilalim nya, ako rin yan din ung mga nasira. ako din prinsipyo ko dapat all stock, napalitan ko lahat ng original parts kaso madugo lng kac sa mahal hindi gaya ng toyota ko ang mura.
October 19th, 2010 01:20 AM #18
na ayos ko na engine support ko mga sir..sa honda spa din pla bagsak ko.heheh
thank you sa mga nag post ng comment.
high idle RPM at engine start
