Results 21 to 30 of 113
February 5th, 2009 11:10 AM #21
Never used E10 in my 1.8S since I got it exactly a year ago. I've always fed primarily with Blaze. If it's not available, I go with V-Power or Gold (in that order).
- Aug 2005
- 205
February 5th, 2009 12:03 PM #22thanks tidus1203. Do we have the same model? Also, afaik, e10 is more combustible, hence giving more power and improves fuel economy. Shell's e10 is based on their regular petrol (89 ron) mixed with 10% ethanol giving a 93 ron. Petron's e10 is based on their unleaded petrol (93 ron) mixed with 10% ethanol giving a 95 ron.
So I concluded that it is possible to get better fuel consumption using petron's e10 compared to using unleaded.
February 5th, 2009 12:13 PM #23
- Aug 2005
- 205
February 5th, 2009 12:37 PM #25
February 5th, 2009 01:28 PM #26
Not so sure siguro nasa 3000++km na yun... Right now my Civic has 5377km in the odometer and in a week 1 year old na Civic ko.
- Aug 2005
- 205
February 5th, 2009 01:42 PM #27
February 5th, 2009 02:05 PM #28
Kung FC ang #1 consideration mo you should have bought the CRDi Accent. Reportedly kaya daw 20km/L. I can't verify that pero seems realistic given diesels frugality and the cars body.
- Aug 2005
- 205
February 5th, 2009 02:17 PM #29my primary consideration is consumption. i also considered interior space and exterior styling. accent has a small interior space. i was about to go with carens (crdi is the way to right!) but i was surprised with the jump in price. my final choices were fd, mazda 3, and the new jazz. mazda 3 was said to have a below avarage fc due to engine power and weight. the fd with the discount is much cheaper than the top of the line jazz. that's why i bought the fd.
- Aug 2005
- 205
February 9th, 2009 08:46 AM #30Ethanol does not increase power. It expands the heat of the petrol creating a bigger explosion. Thus giving your unleaded a higher octane rating. The problem with e10 is that since it expands the heat, the internal temperature of the engine is much higher. This causes knocking issues.
high idle RPM at engine start
