Results 1 to 6 of 6
September 30th, 2014 08:06 PM #1
2 years paso ang rehistro
nawawala ang original copy ng OR CR
puro bangga ang body
walang kalawang
tumatakbo ng maayos hindi lang ngchacharge ang battery...
is it a good buy for 60k?
i want to know kasi if its agood buy for that price, i will sell my car to buy te honda.. kasi gusto ko talaga ng honda..
salamat po sa makakatulong..:
September 30th, 2014 08:38 PM #2
Kung may xcopy yung cr eh hingi ka at ipacheck mo yung car sa tmg to make sure di sya hot car.
Yung body eh makakahintay ipagawa ang mahalaga yung engine.advice ng mga tsikoteers dito e magsama ka ng mekaniko.
Perosnally its a good buy kung ok yung engine at di hot car.
Hope that helps:D
September 30th, 2014 10:26 PM #3
thanks po sir.. actually sa pinsan po ng asawa ko nakapangalan yung kotse... kaya sure po kami na hindi hot car.. and dito po sa amin nakapark..
ang pinoproblema ko lang po is yung papel, baka mahirap makakuha ng orig copy nung cr... lalo na at hindi ako marunong pagdating jan sa pagkuha ng mga papel na yan..hehe
October 1st, 2014 02:54 AM #4
Madugo magasikaso nyan sa lost cr eto alam ko
Need mo ng
orig na or
Xerox ng cr
Affidavit of lost cr
Mv report
Id ng pinsan ng asawa mo
Tin nung pinsan ng asawa mo
Tapos dun I file sa branch ng lto kung san issue yu g cr..
Masmagulo kapag vl nabili mo na at transfer sa name mo ky kung may kakilala ka sa lto ipalakad mo na lang
October 1st, 2014 03:36 AM #5
That's so simple...
Let the owner (cousin of your wife) fix the paper work since legit na siya nakapangalan sa cr.
Pagkakuha ng original ulit, no more problems.
Make sure the transmission and engine is OK. Kung body work lang, panalo na 60k.
Sabihin na natin 45k for respray with latero. OK lang, you could sell it again or keep the car for use.
Replacement parts are so cheap even for water pump, bearings, but original on the timing belt... It won't cost you an arm and a leg.
Imo, go for it basta legit papers ang bigay sayo.
- Oct 2014
- 2
October 11th, 2014 07:24 PM #6Gud day po. may problem po ako sa honda lxi 96 ko. nagrerevolution kc khit hindi ko tinatapakan ung gas.
Maraming Salamat.
high idle RPM at engine start
