Results 1 to 10 of 10
November 18th, 2014 07:17 AM #1
Hello po mga master!!!
Meron po ako hinda city 2004 naka ilaw yun indicator light ng ABS pinadiagnose ko sa HONDA Casa ang findings yun right front ABS sensor daw sira na replacement agad ang recommend kahit di pa sinisilip or nililinis manlang tapos 8k kagad quotation.....wewgrabe
Would like to know baka meron po kayo alam na magaling timingin at mag repair para makamura ako baka kse may adjustment or linis lang or baka may putol na wiring etc....
Patulong po mga sir salamat....
November 19th, 2014 03:45 AM #3
Bring it at Exalta in N. roxas. Tell them to check and clean the ABS sensor. They have an obs scanner to reset the error.
If the sensor is damaged,get the part number from honda, search it on ebay. Its about 2k including shipping.
Wait a month then have it installed.
http://pages.ebay.com/link/?nav=item...d=151450452440
November 19th, 2014 10:32 PM #4
November 20th, 2014 07:10 AM #6
November 21st, 2014 02:02 PM #7
Your brakes will still function normally. But the ABS will not do its job during panic braking.
November 21st, 2014 11:57 PM #8
- Dec 2006
- 57
November 24th, 2014 01:51 PM #9Sir pls keep us updated.
Nagpalinis lang din ako last week sa Exalta ng ABS sensors for 2005 Toyota Fortuner 4x4 D4D.
No ABS warning light,pero mas malakas tunog ng ABS engage kapag first niya nareach 10kph if:
a. hard left, hard right ung manibela kapag nareach 10kph(pinakamalakas na tunog,parang lose gear na hindi kumakapit)
b. medium left, medium right ung manibela kapag nareach 10kph, (may tunog pero mas mahina)
Nagpalinis ako,pero wala nangyari... no improvement.
November 28th, 2014 11:46 PM #10
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
