Results 1 to 3 of 3
August 13th, 2010 07:18 PM #1
Mga honda guru's pa help naman po 1st car ko kasi etong honda city TypZ 2000 2nd hand ko po nabili. gusto ko lang tanong kung araw araw ko ba dapat lagyan ng Tap water yung radiator or hindi ko na kailangan galawin yun basta periodical check lang kung my tubig pa? and yung battery ko po eh enduro so wala nako proproblemahin dun tama ba? and lastly ano pong fuel ang ma recommend niyo sakin? ang ginamit ko po kasi kanina shell super unleaded hehe Pls sana po my sumagot TIA!
August 14th, 2010 10:20 PM #2
Firstly, stop using just water for the radiator and coolant reservoir - that will corrode your radiator from the inside out. You should be using a blend of coolant and distilled water. If you use Honda's coolant, no need for the water.
If your radiator and coolant reservoir need topping up every day, that means your engine's cooling system has a problem.
Stick with 93-octane fuel. Petron Xtra Unleaded works fine.
high idle RPM at engine start
