Page 2 of 2 FirstFirst 12
Results 21 to 40 of 55
    Aug 2014
    Posted the same question on Facebook under JazzCity United Group.
    Here's the link check this baka makatulong. ---> https://www.facebook.com/groups/jazz...=group_comment
    Also if magka solution na yung problem mo (which is lahat sila flywheel ang tinuturo) please share din here. thanks
    Quote Originally Posted by chay View Post
    Hi Sir Doddie, very informative post. we have the same car model. Ask naman ako contacts ng shops outside casa para makamura. Malapit lang ako nakatira sa Honda Otis.
    Issue ko is ung sudden 5 secs freeze from N to D. Plus ung hinde nagststart either sa P or sa N.
    thanks sir!
    Jul 2012
    share k lang..
    Had the same issue with my jazz gd3.. nung una nag slip yung tranny, nag jerk then hindi nag tagal nag bblink na yung "D". once ngyari na sa inyo to cvt tranny issue na tlga. i know replacing the cvt tranny is a drastic step.. pero after researching and asking other jazz owners na may ganitong issue it seems na replace tranny na tlga. got my tranny replaced last Jan by Mel, so far wala ako problema whatsoever.
    Another issue came into play.. nag jjerk kpg idle or mabagal.. usually kpg nsa toll or traffik.. lalo na kapag bukas aircon. replaced my ignition coils.. pinalitan ko na rin spark plugs.. ayun ok na ulit. kinakapos pala ng kuryente kaya nag misfire.
    sana makatulong.
    Aug 2012
    thanks sir!
    thanks sir!
    sir mine is idsi 2006 at, ganyan din problem ko dati ,, jerking , nanginginig ,slipping, ayaw mag start sa P o N... dito din ako sa mga bossing natin sa tsikot nanghingi ng advice at tulong ,, pero i end up na ibenta nlang ung car ko ,, sarap na ng tulog ko kc if you back read talaga sa problem ng idsi eh sasakit na ang ulo mo.. kya i decided na benta nlang khit palugi ,, peace of mind pa din ang mahalaga eh ,, btw dun sa ayaw mag start sa p or n try mo mag switch off sa p tas konting rebolusyon bago patayin makina ,, good luck sir.
    Dec 2009
    Quote Originally Posted by page7fordoddie View Post
    Things i did since January:
    • Replace CVTF at Honda Otis, calibrated - observe.
    • Replace top valve cover gasket at Honda Otis - observe.
    • Change Oil (Motul fully-synthetic)
    • Change all Eight spark plugs, Air filter, Front disk brakes.
    Problems:
    • Vibrates paminsan especially pag heavy gapang traffic.
    • Normal gamitin if city driving if ang takbo is 60kph to 80kph driver only or with one passenger. pero if loaded like apat na passengers medyo nadedelay yung pag shift.
    • If expressway: till 80kph lang if dahan-dahan ang pagbuilt ng speed/momentum pero pag binigla mo ayaw nya, parang manual na humihingi ng shift pero ayaw mag gear-up. pero if unti-unti ang takbo eh nakaka takbo naman ng 100-120 kph.
    Sa observations ko, para sya talagang nagdedelay sa pag dagdag ng kambyo. parang Manual tranny na 80kph na takbo mo pero naka segunda ka pa din.
    Ano problema nito? sadly sa mga napagtatanungan ko eh out of stock ang flywheel. gusto ko na nga sana palitan as sugal move baka machambahan. - Since ang change tranny option is 15k surplus plus labor medyo mahal kaya gusto ko muna maka siguro na CVT tranny or Flywheel nga ang sira bago ko ipatira para hindi masayang pera.
    Please advice. email me doddie.gutierrez*gmail.com or SMS 0927 7555481 if seller kayo ng iDSI Flywheel at tranny for Honda City iDSI 2005.
    Thank You!
    Do you have the habit of keeping the gear in D and just use the break to stop then release the break to move again even in inclined (uphill) or levelled road?
    If the answer is yes, change your driving habit by shifting to N from time to time
    Oct 2019
    Problems:
    Thank You!
    Sir any update dun sa parang hindi sya nagshishift? Gnyan kc skin ang taas ng rpm parang hindi sya nagshishift, nakadalawalang palit na ako transmission pero same issue parin
    Mar 2004
    You might want to try replacing engine and / or transmission mounts.
    Aug 2014
    For the slight vibration, yes i will, altho napasilip ko yung mga engine support okay pa naman. My real concern is yung takbo nya.
    Mar 2004
    You can't really check engine mount by just looking at them. The rubber compound looses it's efficiency after a decade or so.
    Aug 2014
    Thanks sir, will do it on top of my list.
    Guys, I'm really sure the problem is mechanical (tranny, or engine???) any other more inputs please let me know. Thank you!
    Mar 2016
    honda jazz 2005. 1.3 IDSI...The car is a very smooth drive indeed, wala jerk or judder..malakas humatak sa drive(D) pero pag dating sa highway ko nararamdaman.. mahina apak mo going to 80km * 2.5 rpm but after sa tollgate sa nichols mag accelerate na, napapansin ko nag high rpm na sya.. same apak din naman...going to 80km * 3.5rpm na... then medyo bibitawan ko gas pedal.. ayaw na bumaba ng rpm.. para kang nasa 3rd gear lang ng AT.. dapat nasa 7th gear na.. so inaactivate ko nalang yung 7speed mode para bumaba yung RPM at 80km... pero pag deneactivate mo yung 7 speed mode biglang tataas uli yung RPM 3.5...ano kaya problem? thanks
    Dec 2017
    Nagkaprob din ako sa shuddering nang trans for 2 years... Bumili ako nang XADO REVITALIZANT kaka change cvtf ko lang netong sabado.. Observe ko nang ilanv months kung bbalik yung shuddering sa trans..
    Sent from my INE-LX2 using Tapatalk
    Jun 2005
    Quote Originally Posted by Rick21 View Post
    Ipon ka na. Sira yan tranny mo
    Sent from my MI MAX 2 using Tapatalk
    Feb 2020
    Quote Originally Posted by bong06 View Post
    P to D and R shutters, anyone experiencing this on early civics, accords and city??
    Changing your tranny is not the only option ^_^. Its repairable.
    I have a shop in imus cavite... give me a pm maybe i can help you guys out.
    Sir bong, yung sa akin Honda civic 1.8S AT 2008.
    Mataas ang revolution pag start and naka naka check engine na sya, then pag nasa expressway ako from 100 speed biglang mararamdaman mo na humina na ang power nya and kahit mag gas ako ayaw na mag react ng speed. Then mag slow down sa 60 na speed and maramdaman mo mag shi-shift yung gear (may sipa) then ginagawa ko mag stop ako, by the time na mag stop (brake apak ko) pag shift ko ng gear from D to N biglang taas ang rpm nya na parang naka apak ka ng matindi sa gas. Then shift ko sa park at off ko ang makina. Then after mga 5 mins on ko ulit and ok nanaman. Then maitatakbo ko ulit ng mga ilang minutes, then bumabalik ulit sya sa sira. Parang pag uphill saka sya bumabalik sa sira nya.
    Ano kaya sira nitong car ko?
    Jul 2018
    Hi mga sir.
    Planning to change my ATF, okay lang po bang Shell brand or should I get a Authentic Honda ATF? I own a Honda City 2002 A/T model. I'm also open for you comments and suggestions. TYIA.
    Sent from my Redmi Note 7 using Tsikot Forums mobile app
    Quote Originally Posted by batang_angas View Post
    Hi mga sir.
    OEM! Konti lang naman diffeence saka matagal naman magpalit ng ATF.
    Hi mga sir.
    definitely go authentic oem honda atf. maselan ang mga honda pag dating sa mga fluids especially when it comes to a/t trannies.
    Jul 2018
    Noted sir. Thanks. Ilang liters kaya po ang need and how much po per liter ang ganon? Just to have an idea
    iyan ang hindi ako sure kung ilan liters ang ginagamit na atf ng city. consult mo na lang ang manual mo or just google it.
    Jul 2018
    Wala na kasi sir manual to nung nakuha ko. Try ko po sa Google. Anyway, maraming salamat sir!
Honda Automatic transmission problems P to D and R shutters
