Results 31 to 40 of 55
- Aug 2012
- 34
June 21st, 2015 12:19 AM #31sir mine is idsi 2006 at, ganyan din problem ko dati ,, jerking , nanginginig ,slipping, ayaw mag start sa P o N... dito din ako sa mga bossing natin sa tsikot nanghingi ng advice at tulong ,, pero i end up na ibenta nlang ung car ko ,, sarap na ng tulog ko kc if you back read talaga sa problem ng idsi eh sasakit na ang ulo mo.. kya i decided na benta nlang khit palugi ,, peace of mind pa din ang mahalaga eh ,, btw dun sa ayaw mag start sa p or n try mo mag switch off sa p tas konting rebolusyon bago patayin makina ,, good luck sir.
- Mar 2014
- 901
June 29th, 2015 03:57 PM #32
July 23rd, 2015 11:37 AM #33
Talked to Mel Casaba last friday and told me na try ko daw palitan muna mga ignition coil (all 8) kasi daw me napatino sya na ignition lang pinalitan. Ignition coil from casa is 4,800 each x 8=38,400k haha cannot be =)
So nagpunta ako ng Banawe to get surplus. got all 8 for 12k (1,500 isa, surplus) pero i made a deal with the surplus owner na pag hindi tumino means hindi ignition coil ang problem so balik pera ko. PAuwi pa lang ako ramdam ko na walang nangyari me sakit padin so bumalik nako agad to get my money.
Later (Thursday) will go to Mel's place at Cavite to leave the car there for observations and diagnostics. Update ko tong thread by saturday kung ano findings or kung change tranny na talaga.
- May 2011
- 30
July 31st, 2015 10:32 AM #34
July 31st, 2015 07:21 PM #35
- Jul 2012
- 345
July 31st, 2015 09:00 PM #36sir hindi kaya may palyado sa surplus na ignition coil? ako kasi bnew yung pinalit ko na coils.. replacement lang.. hindi from honda. ang kinabit ko yung IKI na brand.. parang napaisip kasi ako sa surplus. ihanda mo na sarili mo bro sa tranny replacement.. i suggest look for a trust worthy mechanic in replacing your tranny if needed. goodluck bro!
- Mar 2014
- 901
July 31st, 2015 09:43 PM #37
- Oct 2015
- 31
- Jul 2012
- 345
high idle RPM at engine start
