Results 1 to 2 of 2
- Jan 2012
- 1
August 3rd, 2014 12:55 AM #1Hello mga Sir/Mam. Newbie lang ako dito pati in owning a car. Just bought a Honda esi 95 second hand.
Ang problema ko bigla na lang namamatay engine maybe after like example: 20min of driving tapos hindi talaga mag-Start ulit maybe after 10-15min then mag-Start na ulit.
It's like it has a mind of it's own. Would start when it wants and won't.
So, in layman's term, tumirik yung auto (Although it cannot be cured with a push). napaCheck ko sa mekaniko ng pinsan ko, tniming, tune-up all (since wala pa talaga ako alam sa car/engine, the whole concept). Okay pa naman daw spark plug, nilinis na rin, pinapalitan ko narin ignition coil kasi biyak nyung nakalagay, okay pa rin naman daw ang battery (I belived it's a non-branded one). Pag-ayaw nang mag-start eh ngrerebolusyon naman so sabi ni mekaniko walang problema sa battery. It's like it's at it's peak point to start while turning the key but would repeat it's trying cycle when it's at it's peak to start the engine.
Pag-nag-start eh parang walang ka proble-problema yung car pati in driving tapos bigla na lang mamamatay and i would wait the said minutes above (Or worst more and more minutes in a day).
Also, if meron makapag-explain po sa inyo ng ibig sabihin ng "palyado makina"? Do the rumors i've heard in vague are true na pag yun ang sinabi eh palit makina na at wala ng pag-asa?
Hope you guys can help me kasi there are many possibilities na sinasabi ng mga nakakausap ko:
Pwede main relay, fuel pump, high retention wire, overheat? Or am i missing more things here.
Gastos kasi mga bossing if ipacheck ko tapos ma-unti-unti lang the "possibilites" said above na mapaltan tapos hindi naman pala yun ang problema.
Also to admin and mods, sorry if this is posted on the wrong section.
Salamat sa mga inputs nyo in advance.
August 5th, 2014 08:23 AM #2
Sa Civic ES, Top Dead Center (TDC) sensor ang problem pag ganyan. Para sigurado dalhin mo sa casa, P600++ ang diagnosis, deductible kung pagagawa mo. Yung TDC ko dati inabot ako P2k+ sama na labor sa Honda Shaw, but that was back in 2009.
That's what he actually did. He also retrofitted an eps to his 1970s era beetle. Btw, now...
A/c
