Results 1 to 11 of 11
    mga sir, san ko po pwede ipacheck ang honda city ko type z? di ko kasi alam kung san nanggagaling ang leak tuwing umuulan ng malakas laging meron tubig sa floorboard ng car ko then nun minsan binuksan ko un trunk napansin ko din basa un mga stuff na nakalagay don..natatakot ako baka meron ng build-up ng kalawang sa sahig ng car..
    sa kalye lang nakapark oto ko since nun mghabagat dinala ko sa place ng friend ko, kasi binaha un garahe kaya lately lang nadiscover na meron leak..
    wala akong alam kung san ko pwede ipacheck kasi wala pang 1 year ng nabili ko oto ko and 1st time ko pa lang din magkaron kaya patulong naman mga sir..
    Feb 2006
    Check the aircon drain for wear and tear. It might be the cause of your wet floor.
    Experienced the same thing with my Innova. Kala ko at first there was a leak in the door panel, weather seal, etc. Kaso I noticed the carpet would get wet even when there was no rain. When I removed the carpet in the front passenger side, yun pala the aircon drain had a tear. So the water would leak underneath the front and rear carpet.
    Oct 2011
    Quote Originally Posted by andycapp View Post
    Share the same experience with you pero kusang nawala ung akin.
    mukhang hindi sa aircon ang problem kasi di ko naman ginagamit car ko almost 2 months na, nakapark lang sya sa tapat ng house ng friend ko and everytime meron biglang ulan na malakas tapos titingnan ng friend ko after ng rain..laging meron tubig na kailangan talaga limasin and sa likod lang lagi ng driver side un..pag marami lang un tubig umaabot sa floor din ng sa driver side..
    Feb 2009
    Quote Originally Posted by jenneth View Post
    to find your leaks, you can try attaching pieces of paper towel around the suspected openings of the car at the trunk lid gasket, at the left rear door and at the weatherstrip of the rear window. the paper will leave trails as to where the water intrusion originated from. you don't have to wait for the next habagat, you can use the garden hose to spray to these areas.
    Aug 2008
    Yup i agree with jick.cejoco.. Weatherstrip (ito yung goma na naiipit pagsinasara yun pinto/trunk) have proper orientation during installation.. Slight misorientation of these weatherstrips usually causes the water to enter the cabin/boot..
    same as mine.. ganyan dn auto q.. nung una kala q sa weather seal, ung black rubber sa my pinto.. pero ndi dun galing eh.. my nkita aq small hole sa my ilalim na chip off cguro ..aun pinaaus q sa mekaniko w/c specializes in body works.. mula nun ok na..
    Experienced the same thing sa EK ko and mystified the hell out of me for a long time, pero nasolve ni nurse Eldie ng Bukid Tuning dito sa Laguna (thanks man!)
    Not sure kung exact same ang problema sa city mo, but may be the same since honda naman. There's a vent dun sa may driver's side ng rear bumper (you have to remove the bumper to access it) at yun yung may leak sa gasket nya. Pressure vent ata ito para pag sinara yung door at trunk.. Not sure what the exact function is. Nilagyan ng silicon yung gilid, ayun problem solved. Nangyari is yung leak dun ay napupunta sa trunk (kaya basa yung carpeting sa trunk) then pag nagspillover ay napupunta sa passenger compartment sa likod.. Kaya nababasa yung upuan sa likod.
    Hope this helps you out or other guys with the same issue.
    Sent from my GT-P6800 using Tapatalk 2
    ^ had the same problem and the same solution for my ek back then.
    may pics pa iyan ng how to sa hcp.
    Sep 2012
    hi jenneth, we both have the same brand and model, honda city type z. same problem as well.. how is it? have u tried any of those recommendations from our sirs? nwala na ba leaks inside your car?
    Quote Originally Posted by koyki101 View Post
    hi koyki101 now lang ako ulit nakapag-check dito..nakita ko na kung san galing ang leak ginawa ko un suggestion ni jick..gumamit kami ng friend ko ng garden hose nag-concentrate lang kami sa may bandang trunk..ayun nakita namin nasa bandang gilid ng trunk inangat ko un carpet na malapit sa tail light meron ako nakita butas nilagyan ko na lang ng steel epoxy..after non ok na wala nang tubig na pumapasok sa city ko..
help..water on the rear passenger floorboard (driver side)
