Results 1 to 12 of 12
    Guys ung Sir ko walang busina ok naman ang fuse, kapag liliko ako tumutunog ung busina.. helpo naman po.. ty
    Oct 2007
    sir, stock po ba yung busina niyo o aftermarket na.check mo muna mga fuse bro at saka wirings mo.
    Quote Originally Posted by oakley23 View Post
    probably grounded wirings yan bro or busted relays since pag lumiliko ka bumubusina.
    thanks sa reply, stock pa po ung busina ko, ok naman ung fuse, cguro nga ung relay. pero pano ko ma check kung buo pa ung relay?
    relays mostly can't be checked via visual inspection. minsan, it may look ok but the internal circuitry has been damaged. mura lang naman relay, papalitan mo na lang.
    ^^ tama tama... the relay is your best bet sa ganyan...
    do a visual inspection, then kung walang damage fuse, open wires, etc. then relay na lang talaga best bet mo.
    thanks mga pards sa quick reply nyo.. palitan ko na lang ang relay.. salamat po.
HELP!! SiR walang busina
