Results 1 to 13 of 13
    Jan 2008
    Mga sir bibili na sana ako ng mags kanina but i noticed na lahat ng
    Aftermarket wheels na gusto ko has a larger hub opening than the stock hub size.
    Ok lang ba yun? May mga gumagamit ba sa inyo ng "hub rings" and san nakakakuha nun?
    Di ba masama kung puro stud lang ang humahawak sa weight ng car? thanks again
    IMO i would not recommend this... just get the right size for your ride for safety purposes.
    Dec 2007
    The center spigot is what supports the weight of the vehicle, not the wheel's lugs/studs. You will need a wheel that will fit the spigot without any play.
    Definitely a NO for hub rings. Hanap ka na lang ng ibang gulong.
    Dec 2007
    It seems I stand corrected...Most aftermarket wheels, it seems, will need hub-centric rings after all.
    Here's a link and a helpful explanation, courtesy of Redorange:
    http://planetsoarer.com/offset/studs.htm
    I'm now also on the lookout for hub-centric rings as my wheels need them too. Any suggestions on where to buy them?
    Jan 2008
    Quote Originally Posted by Type 100 View Post
    type 100
    sir i've called sa rota meron daw sila. kaso past 5pm na kanina so tawag na lang daw again ako sa monday.
    i've searched din sa mga tire shop sa evangelista pero di nila alam yun.
    yung minerva tire shop lang at alabang ang nakaka alam pero they dont have it, but they suggest na mag pagawa na lang ako sa machine shop cuz yung ibang kinabitan daw nila ay nag pag gawa pa sa machine shop.
    so i went sa c.c. barleta machine shop and gumagawa nga sila.
    pero hintayin ko muna yung sa rota sa monday kung meron talaga. balitaan kita sir
    Dec 2007
    Thanks Dante. Yeah, mukhang fabricate na nga lang. Tried calling up Wheelhaus along Evangelista (where I got my wheels from) and they didn't know about it. Actually it's very surprising how almost no one in the local car industry knows of hub-centric rings...
    I have a contact from Rota who sells rims on HCP and AutoIndustriya. Called him up an hour ago and he says he doesn't know of them making hub-centric rings. He would rather just sell you a set of rims that will fit flush with the spigot.
    But if you say Rota makes them...hmmm...I can check them out at their factory the week after next Kung wala eh di fabricate na rin ako, o pasadya ako ng order sa mga kakilala sa US at doon marami nyan
Help on rims? Thanks
