Results 1 to 12 of 12
    Jan 2008
    meron akong honda ESI, ang problema eh yung menor bumababa parang loosing some power eh napalinis ko na trotle nito had new oil filter and engine one click.
    while driving ramdam mo na parang bitin ang makina so tendency parang palyado... ano kaya problem?
    help?
    Jan 2008
    BTW air filter is good BN eh.. help lang
    inputs will be appreciated
    did you change the spark plugs?
    check mo, malamang may busted na diyan.
    Jan 2008
    sir salamat sa replay kapapalit lang den ng sparkplug
    pati sparkplug oil seal palit na den ako d kaya high tension wire yun? sabi naman ng mekaniko ko walang problem dun kasi d naman sya nakukuryente stock paden un eh
    hmmm... usually palyado comes from misfiring...
    try to pull out each wire from the spark plug while the engine is running... dapat magiiba yung tunog niyan, if not then you found your culprit.
    just be careful while doing this. baka maelectrical shock ka.
    Sep 2005
    check mo rin fuel filter, baka barado or puro kalawan na. also check fuel pump. hth
    May 2007
    Quote Originally Posted by hondaesi View Post
    help?
    Could be anything. When this things happen? Have you done anything to the car lately I mean anything? Update me.
    Jan 2008
    update mga sir
    BN fuel filter ko
    wala naman akong binago sa engine stock ph16 parin aside from the cone air filter open type that im using.
    and the car had its tune up done preventive maintenance (change oil and oil filter, spark plug done) my mechanic advised that there is nothing wrong naman its the process of changing gear daw when im driving that's the problem
    my normal change of gear are as follow:
    1st to 2nd gear * 20kph
    2nd to 3rd gear * 30kph
    3rd to 4th gear * 40kph
    4th to 5th gear * 60kph
    been doing this ever since even on my other old car (not 16 valve)
    now lang ako naka ramdam ng ganito with this.
    anything im doing wrong? tnx
    May 2007
    Palitan mo muna yong fuel filter baka barado lang. If not,maaari din bad fuel pressure regulator kung fuel injected, o kaya you have a bad float, needle or seat kung carburator ang tsikot mo. Pa fuel pressure test mo yong system ng tsikot mo para malaman kung saan diyan ang palya. Kapag hindi yan ang problema, update ka uli dahil like I said maraming dahilan ang pagkasakit ng tsikot mo.
    Hints:
    Lahat na ginagawa nila sa makina mo, take note mo para sa ganoon sa susunod ay alam mo na ang gagawin mo. That's what I do!
    Jan 2008
    ok sir thank you sa info
    matagal ba gawin yun? how much the cost if that would be the problem?
    May 2007
    Mura lang canvas sa mga shop o di kaya ask here sa tsikot kung saan ang murang pagawaan nito. Palit ka muna ng fuel filter, kaya mo yan madaling palitan. update.
tulong lang
