Hey guys! Just wondering if you can help me with my automatic transmission problems. I have a Honda Accord that has about 100,500 miles. Every time I shift from park to drive the car jerks immensely forward as though it had just been rear ended & makes a clunking noise. It does this to every gear except neutral. Also when I shift it from drive to park it makes a loud clunking/grinding noise. The transmission is very hard to shift. I have to apply a lot of pressure to the shifter in order to change gear. I had the automatic transmission fluid drained & filled with Honda ATF fluid about 4 months ago & I also added a bottle of LUCAS transmission fix but it didn’t fix the problem. Could it be that my transmission mount is worn out? Do I need a complete transmission flush to eliminate the clunking/grinding? Any suggestions or comments would be appreciated. Thanks in advance!
