Results 1 to 17 of 17
    Sep 2004
    Hey guys! Just wondering if you can help me with my automatic transmission problems. I have a Honda Accord that has about 100,500 miles. Every time I shift from park to drive the car jerks immensely forward as though it had just been rear ended & makes a clunking noise. It does this to every gear except neutral. Also when I shift it from drive to park it makes a loud clunking/grinding noise. The transmission is very hard to shift. I have to apply a lot of pressure to the shifter in order to change gear. I had the automatic transmission fluid drained & filled with Honda ATF fluid about 4 months ago & I also added a bottle of LUCAS transmission fix but it didn’t fix the problem. Could it be that my transmission mount is worn out? Do I need a complete transmission flush to eliminate the clunking/grinding? Any suggestions or comments would be appreciated. Thanks in advance!
    Feb 2003
    just my 2 cents, better bring it to any Honda dealership near your location,
    have a professional technician test drive your ride so they can have a more detailed diagnostic of your car. if you're near Shaw blvd. bring ur ride to Honda Shaw. Look for Elmer. He's the foreman there. He's the best that I know can troubleshoot any problems.
    Jul 2005
    hello my family owns a '97 honda city exi.
    recently the automatic transmission got busted. i was wondering if anybody here can give me a ball park figure of how much it would cost me to have it repaired and where is a good place i can have it repaired (aside from casa)?
    hope someone could answer my query, thank you in advance.
  4. #4
    punta ka nalang sa surplusan, sa banawe(e.rod,quezon ave side inparticular, and just buy an surplus tranny.
    but bago mo ikabit, have all the fluid draid, lalo na sa torque converter. down mo yung oil pan ng a/t, the linis/palit ung filter inside. prepare 7-9 liters of CORRECT SPEC ATF...if in doubt, buy an ATF from casa(wag ka pumayag na basta kahit anong ATF ang ilagay!)
    mas mura ang palit surplus than overhaul...i know ginawa ko na to,e..sa liteace ko.
    shift shock tawag dun. might be worn out na yung belt that hold the planet gear. overhaul na yan. or better yet palit ng surplus as suggested by AY since mas mura ang surplus tranny kesa sa overhaul.
    Jul 2005
    *always_yummy, yebo
    mga sirs salamat sa reply. sige try ko yun surplus mejo mahal kasi talaga yun pa overhaul, ang quote sa akin ay kulang kulang 30k.
    mga magkano kaya estimate kung surplus lang, mga sir? malaki kaya matitipid ko?
    ps
    bakit hindi pwede yun ordinary ATF? madalas ko kasing gamitin yun nabibili lang sa gasolinahan, petron or shell.
    Sep 2004
    Yup, tama sila, cheaper to buy surplus than to overhaul. Besides, usually pareho lang ang length ng warranty (3 mos.)
    For a 97 City EXi, I would assume it would be less than 14k. Kasi I got a quote for that amount for my 97 Accord. Installation labor ~3k.
    For the ATF, better na you get the same spec as that listed in the manual. Dexron II lang yata ang 97 EXi. Most ordinary ATF naman, Dexron II na, kaya pwede sya
  8. #8
    noon di ko din alalm yun, pero since i ownd my 1st matic(subic delica a/t) nalaman kong di lahat ng fluid (atf) pare pareho, nagkakatalo yan 1. sa lapot, at sa fluid characteristics(temp. tolerance,etc..)
    kaya follow what's engraved sa dip-stick/owner's manual mo.
    Jul 2005
    *galactus, always yummy
    mga sirs thanks talaga you've helped me a lot. thats almost 50% savings, sige one of these saturdays iikot ako ng banawe to find a surplus (at yun may warranty, ).
    thank you for the headsup on the atf fluid. sige i'll check my manual for the exact rating.
    OT:
    to be honest sirs my primary ride nowadays is a motorcycle (150cc). the honda is mostly used by my dad or my sister.
    kakatawa nga eh, kapag manghihiram ako -- car "nila"; pero tuwing masisira -- car "ko" bigla. hahahaha!
  10. #10
    pagiikot ka sa banawe, wag ka dala sasakyan, kasi nasa suloks ang mga great deals, para iwas free-lancers din...makatwad ng maayos..
    Jul 2005
    great advice thanks!
    Jul 2006
    OT medyo. yung shift shock po ba sa honda na wala namang sound (shift shock lang talaga) is normal?
    Jul 2005
    Quote Originally Posted by eliteimage View Post
    <moderator i made a mistake please delete this post. thanks.>
    sir ask ko lang problem ko sa hoda vtec96, this is my firt time to use automatic tranmission... pansin ko lang mabagal ang pick up pag naka aircon eh.. bakkit kaya.. help me naman..
    Feb 2007
    merron akong mekaniko sya nag aalaga ng truck and 3 cars nmen.
    magaling sya and kaya nyang mag overhaul ng transmission kahit a/t pa...
    sa las pinas mga ser.. labor nya is less than 20k. kumpara mo sa casa.
    kung trip nyo, sabihan nyo lang ako.
    Jul 2005
    Quote Originally Posted by ariz View Post
    just an update folks, turned out it was my CV joint that got busted, transmission is still relatively okay, its working fine now. total damage 9k petots.
    thanks to everyone that offered their advice!
    May 2007
    Quote Originally Posted by honda_vtec View Post
    Your aircon compressor can grab enought power from your engine during acceleration. Try to turn off the A/C during take off and turn it on during normal cruise.
automatic tranny problems pls.help
