Results 1 to 20 of 23
    Sep 2009
    Can you guys help me out...i want to tune the engine of my car...but i dont know where to start.. Help pls...
    Quote Originally Posted by kvincent11 View Post
    Whats the problem? Why do you want to tune your car.
    If you want to get a good tune result .
    Check the following .
    1. Spark plug condition - Take a look one by one see the color .If black lots of carbon . wet with oil , brownish light in color
    2. Cllean air filter
    3.Check the condition of your spark plug wire set . The tip might be corroded or rusty .
    4. Check the engine timing . Timing must be set on your engine specification.
    5. Check disributor cap, rotor
    NOTE # When was the last tune -up of your engine. Including change oil.
    Hope this help answer your question. Just give more detail so other tsikoteer will answer your question briefly.
    i think the guy meant TUNE as in race tuning
    not tune up
    Do you want want more power or better handling. I would assume you would like to have more power at the moment.
    Figure out what kind of budget you have and visit SPEEDLAB.
    UNICHIP ftw!
    Quote Originally Posted by ssaloon View Post
    UNICHIP ftw!
    But unichip on a fully stock engine will only gain so much. The car would gain more with SPEEDLAB's intake, headers and exhaust upgrades.
    Bro, I think you need to select some stages before tuning your car.
    Stage 1. Replace your intake and exhaust system
    Stage 2. Get a blow off valve and induction kit
    Stage 3. Need your electrical and computer system replace like ECU chip for fuel distribution
    Stage 4. Replace your Gears and drive train to a racing kit like sequential shifter and bigger gear ratio.
    Stage 5. Change your breaks to a ceramic disk for better breaking system.
    Stage 6. Bore up kits and engine works for ever sized pistons.
    Stage 7. NOS!
    Mamili ka nalang dyan, pero kung may pera ka at balak mong kalabanin ang x-wing ng star wars. gawin mo lahat yan. Hehehehehe
    Nabasa ko (from sidney/speedlab's post sa teamFD) that the 1.8L R18s don't really benefit from changing exhausts.
    Drop by speedlab na rin for the stage1 upgrades, before you'd think of dropping down ~150k for a turbo setup.
    Aug 2004
    Quote Originally Posted by scratch View Post
    Don't need a blow-off valve without forced induction.
    Good luck finding a sequential box for the R18.
    And good luck finding and installing one for under a million pesos... because a sequential racing box alone costs more than that.
    That's brakes. Good luck finding ceramic brake discs for the Honda, too... unless you have access to a wrecked Porsche and can somehow fit those gigantic rotors and calipers under the Civic's wheel-wells
    That's oversized.
    Stage 7. NOS!
    And that's nitrous. NOS is just a brand-name. You can buy an NOS fuel additive or energy drink... neither of which will give you any additional power. :hysterical:
    C'mon, the guy was asking a serious question...
    The problem with changing exhausts on the R18 is that the big restriction is with the built-in exhaust manifold... but you can probably make some decent gains with the downpipe (if it's a single pipe, can you call it a "header" (-s) :hysterical: ), a full exhaust and a chip. The R18 should do well with the Unichip, actually, since it's electronic ignition as well as injection, and the Unichip makes a lot of its gains through the dynamic timing control of the ignition system.
    The R18 is already actually pretty powerful for a 1.8... it's as quick as most of the 2.0s on the market, bar the Focus TDCi. In fact, when we first drove the manual 1.8, both I and my cousin were mighty impressed. (I drive a 2.0 Ford Lynx RS... he drives an SiR).
    I'd personally do a cold-air induction set-up and a Unichip, then focus on brakes and suspension.
    The turbo would be nice, and the single exhaust port of the R18 makes installation simpler, but it's not for everyone... if you simply want to make your car a bit quicker, no need for a turbo.
    Stage 7. NOS!
    walang turbo yung civic ng threadstarter, aanuhin niya ang BOV? DUH
    and the BOV has nothing to do with added power. it's function is to protect the turbo from damage caused by compressed air backing up when the throttle closes
    sequential gearbox? like a 6 speed Xtrac? ok ka lang dude? the guy's not building a race car
    it's brakes dude. upgrade brake pads first, if not enough stopping power, then change the rotors and calipers
    machine the engine to increase displacement? later dude. Much later. he could have sold the car before getting to that
    NOS? watched Fast and Furious too many times huh? it's not stage 7 dude.
    you can go nitrous even at stage 1 if you like.
    BTW, who cares to count beyond stage 3?
    Sep 2009
    if I were you... wait for one more year... sayang ung makina mo sariwa pa yan... pero kung toy car mo lang yan then go ahead... they've said all the right steps for a stage by stage upgrade may the force be with you
Help...I want to tune my engine...Civic 08
