Results 1 to 6 of 6
- Jun 2006
- 12
August 15th, 2009 09:01 PM #1Honda civic 1.5 lxi 97
Please help po... I noticed that my idling is erratic pag nakaaircon lalo sa tanghali at tirik ang araw ayun kulang sa lamig ang aircon...tapos na observe ko rin parang on and off ang compressor kasi maramdaman mo pag nag click sya...
normal pag gabi kasi di na miinit at yun malamig aircon...
napansin ko rin pag tanghali at nakaircon parang hesitant ang arangkada pero very mild lang naman.
ano po kaya problem? Thanks in advance.
August 15th, 2009 09:28 PM #2
Possible causes of erratric idling
1. Last time throttle body clean. Might have lots of carbon inside .
2. MAF sensor . need to be clean . MASS AIR FLOW.
3. Last tune up. CHANGE spark plug .hows your spark plug burn . spark plug wire set.
its good if you install grounding kit mostly stock grounding for long time get rusty .
- Jun 2006
- 12
August 15th, 2009 11:45 PM #3
August 16th, 2009 12:27 AM #4
I agree with the MAF cleanup. Most probably an old car will need to have this done. Add to this throttle (and perhaps servo) cleaning. Imagine mo 12 years na naipon sa MAF, throttle at servo yung dumi. And most who do car tuning do not clean these parts.
- Feb 2011
- 2
February 5th, 2011 05:23 PM #5ok na ba sir trouble sa idling ng civic u? anong napagawa mo para maging ok pati ung sinasabi mo pag na ka idle e on and off compressor? reply ASAP
- Jun 2009
- 8
February 7th, 2011 12:22 PM #6Pasingit mga bro.
Yun MAF ba pwede DIY cleaning or dapat professional? San part ng civic nakikita ito and what does it look like?
Thanks.
high idle RPM at engine start
