Results 1 to 2 of 2
- Sep 2009
- 1
September 8th, 2009 03:35 AM #1hi po mga sir,ask ko lang po kung bakit pag inistart kong i-switch ang key ng auto ko(96' civic vti)hindi po umiilaw yung battery indicator,kapapagawa ko lang ng alternator last few days,then nung nagpunta ko sa auto electrician para ipa-check ko kung bakit di nailaw indicator e2 mga sagot nila...
1.sira IC ng alternator mo
2.sira buong alternator mo tera't palitan ko iho.
3.voltage regulator yan brad
4.pundido na ang bulb ng indicator mo
baka po meron na po kayong na-experience na ganitong problem sa civic nyo baka pwede nyo naman po i-share kung paano nyo na-solve
about sa alternator ko na ipinagawa ilang mechanic nagcheck at sabi namn na nagcha-charge yung battery bale nasa 13.5 volts to 14 volts,ok din pagnakabukas lahat ng lights and aircon.battery nya last 2 weeks ko lang nabili.
- Sep 2009
- 9
September 9th, 2009 12:10 AM #2First check the indicator light assuming it was working fine before u got u'r alternator fixed... Maybe they just tooked it out... Try taking the gauge and see if there is a bulb behind it...
The battery indicator light should turn on then off when u switch the car...
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
