Results 1 to 10 of 10
January 8th, 2009 08:06 AM #1
guys why kaya ung air con ng sasakyan di sa pinaka diffuser lumalabas sa may malapit sa windshield siya bumubuga? kaya laging nag fog windshield. help! thank you!
January 8th, 2009 08:28 AM #2
Sir what's your ride?...baka yun vent ng aircon near the windshield is open?...check your aircon settings (the drawings sa dashboard)...baka naka set yun aircon to blow sa vent near the windshield and not sa diffuser...good luck.
January 8th, 2009 09:47 AM #3
January 8th, 2009 10:13 AM #4
- Jan 2009
- 21
January 14th, 2009 02:50 AM #6tinangal na ba dash mo?? kc yung sken ganyan din nagyari... nung nagparepair ako ng wiring.. sa baba naman lulabas yung lamig..
January 15th, 2009 01:01 AM #7
bro di pa na dismantle ung dash. Double check ko siguro ung setting ng a/c
January 22nd, 2009 08:47 AM #8
guys ganun parin,problem ng a/c after ma check ung settings,any idea? thank you!!
January 22nd, 2009 09:18 AM #9
I would suggest you find the vacuum ball in the engine compartment. Some cars vacuum ball are located behind the front bumper and some have them on the firewall. There may be a hole in the vacuum line. So when the engine finally builds up enough vacuum the door changes redirecting the air flow to the selected location.
Or
The actuator, or door is probably broke, look up under the dash and you should see some linkages, you can move these by hand to see what's broke or move the mode on the control head and watch them to see if they are moving or not. could also be the control head.
January 22nd, 2009 09:35 AM #10
Yup, malamang stuck na yung vent controller sa windshield position.
Check mo na lang kung may maririnig kang may tunog pag switch mo other vent positions. It usually makes a sound about 2 secs after you switch it.
Xiaomi E-Car
