i suggest you give the car a full service:
1. new spark plugs (use NGK bkr6e)
Honda Shaw used Honda plugs
2. new oil (try 10w-40 grade)
casa used Honda oil...will check again kung 10w-40 yung viscosity
3. new transmission oil (use only honda ATF)
kasama din ito sa pinalitan nila
4. get the valve tappets adjusted and timing back to spec (baka naka advance yan)
this I have to get checked
5. have the throttle body and MAF sensors cleaned (again, casa can do this)
will have this done kasabay ng pa-check ng timing (but DEFINITELY not with Honda SHAW
6. check your tire pressures (put 31 psi all around)
will do that, sir
7. switch to better fuel (try caltex with technron so you clean the injectors too)
using PETRON XCS right now...subukan ko mag-CALTEX Techron just to compare
the LXi has a small engine, but it should not do 5km to the liter normal traffic. lagi ka ba nakahinto sa traffic? running on idle at traffice gets you zero km/liter.
madalas nga ako ma-traffic sir...short-trips din madalas (less than 10kms)
