Results 1 to 10 of 21
- May 2010
- 13
May 26th, 2010 02:15 PM #1My recently acquired '96 Civic LXi had fuel consumption of a little above 5km/L. Purely city driving with moderate-to-heavy traffic and lots of short trips.
And there I was thinking it will be a more fuel-efficient replacement for my 16-V corolla when I acquired it 2 weeks ago. Only to find out na daig ko pa ang naka-SUV sa lakas nya sa gas!!
Per documents from previous owner, casa-maintained naman sya (HONDA Shaw). Regular din ang mga preventive maintenance (oil, filters, plugs).
Ano-ano mga dapat kong ipa-check to improve its fuel consumption? Tulong naman po!
May 26th, 2010 04:42 PM #2
What transmission did your Corolla have? What transmission does your Civic have?
And what's your daily commute like?
- May 2010
- 13
May 26th, 2010 10:51 PM #3
- May 2010
- 13
May 26th, 2010 11:39 PM #5
May 26th, 2010 11:41 PM #6
ganyan din mazda 3 namen dati. bnew pa yun. so i guess normal lang yan. lalu na kung puro short trip (3-4kms)
May 27th, 2010 12:15 AM #7
it should not be that high. 7kms/l i think would be acceptable.
any mods done to the car by previous owner?
an idle niya? hard to believe na ganyan kalakas sa gas LXi
- May 2010
- 13
May 27th, 2010 07:07 AM #8oo nga sir archie eh...OK lang sana kung mga 7+km/L dahil puro short trips nga tapos traffic pa arwa-araw...pero hindi naman ganito na less than 6km/L
all stock din yung oto since galing nga ito sa company bidding...idle seems OK...mataas lang sa cold start ng konti pero returns to about 700-800 pag normal operating temp na.
would any of the following be possible culprits for this unacceptable F/C...dirty throttle, IACV, and MAP sensor?
- Apr 2009
- 1,902
May 27th, 2010 07:22 AM #9This is normal on Honda EFI engines. They normally idle on 1500 rpm on cold starts.
One symptom of a dirty throttle body, iacv and map sensor would be erratic (inconsistent) idling.
Paps kung sa tingin mo ay ok naman at malinis lahat ng visible parts (throttle body/air filter/fuel filter/non-faulty brakes/no suspension-tire contact etc) na pwede mo i-check for good condition, maaring yung mga invisble parts (ECU fuel map data, MAP sensor [you could be running too rich]) ang gustuhin mong ipa-check naman kung ok ang kondisyon.
Yung tropa ko naka-matic LXi din naman eh. All good condition yung engine, ecu and suspension niya kala lang matakaw pa din daw sa gas kasi "sliding" daw yung torque converter niya (yun ang sabi niya, although wala akong masyadong alam how A/T works).
May 27th, 2010 09:46 AM #10
i suggest you give the car a full service:
1. new spark plugs (use NGK bkr6e)
2. new oil (try 10w-40 grade)
3. new transmission oil (use only honda ATF)
4. get the valve tappets adjusted and timing back to spec (baka naka advance yan)
5. have the throttle body and MAF sensors cleaned (again, casa can do this)
6. check your tire pressures (put 31 psi all around)
7. switch to better fuel (try caltex with technron so you clean the injectors too)
the LXi has a small engine, but it should not do 5km to the liter normal traffic. lagi ka ba nakahinto sa traffic? running on idle at traffice gets you zero km/liter.
Xiaomi E-Car
