Results 1 to 5 of 5
    Jan 2013
    Mga paps, magkano kaya aabutin lahat lahat yung enigne transpalnt ng d15b sa civic lxi 98, salamat sa sasagot
    Same mounting points, same dimensions, same supports, different wiring because of vtec. Depende sa singil ng electrician. Sa tingin ko around 15k to 20k. IMHO, swap the head para may vtec na.
    Wala pa change engine cost. If you have 20 cam lobes ok na pero kung vtec3, wag na. Mahina 3 stage vtec.
    Edit: ano ecu kasama? Kung hindi programmable, mas mahal aabutin. Sayang vtec kung hindi matotono.
    Jan 2013
    Quote Originally Posted by [archie] View Post
    15 to 20k wiring pa lang yun bro, how much kaya yung engine mismo? magkano kaya value ng ph15 engine ko wala naman ako pag gagamitan naman nito eh, yung budget ko kasi is 60k lang sagad na yun.
    Depende sir kung kalas kabit lang makina, mga 5k or less may papatol na mechanic.
    Electrician, depende kung may harness na or rewire Lahat. Mga 10k to 15k.
    Ecu, p06 for Matic or p08 manual. Rechip, rewire... Around 10k all in
    Tuner 10k
    Dyno 5k per hour.
    Set aside around 5k for for unforseen gastos like gas change engine registry etc. Wala pa diyan yung engine cost itself. Medyo mahal aabutin.
    Cheaper way is to swap the head to vtec. Retain the block. Wala na kalas kabit ng engine.
    Head, gaskets, Ecu, cams, rewire, tuning na lang.
    Edit: value ng ph15 head block? Not sure pero mababa bentahan ang alam ko.
    Feb 2014
    Tuner 10k
    Dyno 5k per hour.
    Sir ano po tuner n dyno sa makina?tnx
engine transplant
