Quote Originally Posted by edge868 View Post
Hello mga sirs,
I'm having problems with my 2000 honda civic vti manual lately. It overheated last september so i had the cylinder head gasket replaced. Then after 2 months it overheated again, so the cylinder head gasket was replaced again and the head cylinder was resurfaced by a machine shop.
i noticed however that i needed to add water to the radiator every morning, so i had the radiator overhauled and the hoses checked. Still the same problem and then i noticed whitish/brownish color in the oil dipstick.
The mechanic then tightened the cylinder head bolts from 65 t0 75 torque and changed the oil and filter. I still see traces of whitish color in the dipstick but not as much as before.
Although the temp remains at half or normal, i still need to add water everyday (about the amount of a small bottle of mineral water).
What can be the real problem? I need all the professional advice you can give. Thanks.
We got the same ride, mine is a/t, what was the cause of the overheat?
