Originally Posted by
voltscastillo
you have a honda civic EG with a swapped d15 vtec engine? or a non vtec ph15 engine? magkaiba yun. the latter came in standard in all Esi's...
good car, and if the orig engine's been replaced with a d15 surplus, well, even better.
all hondas are known for reliability. if you take care of your eg, she'll take care of you. konting kuliglig lng na marinig/ramdam mo somewhere, either sa engine or sa pang-ilalim, pa check mo agad para hinde mag multiply problema.
your EG has a nice dashboard. it's the best i've seen in any honda i've owned.
usual maintenance stuff. use a lighter oil than 20w-50. and always change the oil at 5-6000T kms. sparkplugs too. if you do have a d15, have the valve tappet clearances adjusted every now and then.
